Inspektion II
Cristianu
Salutari.
Vine Inspection II si am luat din softul Autodata chestiile care trebuie facute la aceasta inspectie.
Avand in vedere ca nu avem reprezentanta BMW in Oradea, o voi face probabil la un service cat de cat mai rasarit ( Bosch Car Service, Autocenter) si am nevoie de putin ajutor cu traducerile. ( presupunand ca daca merg cu foaia in engleza sau germana se vor uita ciudat la mine...)
Atasez aici cele 2 pagini cu ce am de facut
am nevoie de traducere la cele incercuite, la care nu am trecut nimic la mentiuni, cele cu liniuta le stiu si fac singur verificarile, deci ies din discutie.
Astea au mai ramas :
footbrake si handbrake travel
clutch hydraulic system
steering rack/box
PAS hoses
Suspension joints/seals/gaiters
Drive Shaft joints/seals/gaiters
Rear diferential oil leaks
Road springs
Shock absorbers/mountings
Brake pipe corrosion
Underbody condition/sealant
front wheel bearings
Brake hydraulic system
Baterry/specific gravity
Steering free-play
Vreau sa o fac bine, stand langa masina si de asta ma interesez. :twoup:
footbrake si handbrake travel - circuitul franei de seviciu si de mana
clutch hydraulic system - sistem hidraulic ambreaj
steering rack/box - caseta directie
PAS hoses - furtune servodirectie
Suspension joints/seals/gaiters - garnituri, imbinari ,suspensie
Drive Shaft joints/seals/gaiters - garnituri ,imbinari ,ax cardan
Rear diferential oil leaks - pierderi ulei diferential spate
Road springs - arcuri
Shock absorbers/mountings - amortizoare / flanse
Brake pipe corrosion - grad rugina conducta frana
Underbody condition/sealant - aspect pedalier , antifonare
front wheel bearings - rulmenti fata
Brake hydraulic system - sistem franare hidraulic
Baterry/specific gravity - conditie acumulator
Steering free-play - joc volan
Nu dati cu pietre in mine daca nu este corect :twoup:
