dash pc 2
  • Replies 176
Posted Images
  On 1/8/2010 at 1:11 PM, mynamevalentin said:
mar interesa si pe mine un sistem asa. dar un laptop nu merge pus?
vezi ca exista de la intel o placa de baza cu procesor dual-core atom - miniITX , fara cooler .... cu un SSD faci ce vrei apoi ....cu 2Gb de RAM merge xp si win 7 fara probleme pe el.... am facut un mini server pt un dispecerat bazat pe solutia asta ... si este foarte ieftina... depinde si ce SSD pui .... dar cu max 250USD ar trebui sa'l poti face.
INTEL BLKD510MO "Mount Olive" Essential Series NM10 + CPU Atom D510 DualCore 1.66GHz / 512KB X2 L2 cache (Mini-ITX,533 MHz,2 DDR II,1 PCI & PCIe mini slot, 6 Channel HD Audio (with multi streaming Support),SVGA+S-video,GbELAN,2 xSATA, 8xUSB2) Windows Vista* Basic WHQL certified, Windows 7* Starter / Home Basic support, bulk
INTEL BLKD525MW Essential Series iNM10 Express iAtom D525 Dual Core 1.8Ghz /MB cache,(2x DDR3/1066 SODIMM, Mini-ITX,Int VGA /DirectX9,GbLAN, PCI&PCIe mini slot,SATAII/PATA,8xUSB2.0,support Vista Basic & Windows 7* Starter)
