Intrebare cutie steptronic E46
Astazi dimineata dupa ce am mers vreo 5 km, acolo unde imi arata in ce trapta de viteza sunt ( in bord), a aparut o steluta galbena si in interiorul ei avea " ! ". Am oprit motorul, am stat cateva secunde si cand am pornit iar disparuse.
Am intrebat pe cineva si mi-a zis ca a intrat cutia in modul de avarie :blink:
Aveti idee ce inseamna semnul asta?
P.S. Am sa postez niste poze poate va dati seama ce inseamna.
Citez din manual:
Electronic transmission control
module
If the indicator lamp comes on,
there is a malfunction in the
transmission system.
Bring the vehicle to a stop, select transmission
position "P," set the parking
brake and turn the engine off (ignition
key to position 0).
Wait a few seconds, then start the
engine.
If the indicator lamp goes out after a
few seconds, normal transmission performance
has been restored. You may
continue to drive as usual.
If the indicator lamp does not go out,
you can place the selector lever in all
positions. However, the vehicle will now
only operate in 3rd and 4th gear.
If this happens, avoid extreme engine
loads and consult the nearest BMW
center
" Bring the vehicle to a stop, select transmission
key to position 0).
engine.
continue to drive as usual. "
Asta am facut eu.....
O fi normal, o fi vreo defectiune, nu stiu ce sa cred....... :blink:
