Program intretinere AUTODATA
capusangaby
Salutare.
Mi-am facut schimbu de ulei si nu am stiut sa resetez calculatoru. am cautat pe tot netu si nu am gasit la modelu meu.
am fost la Bosch in Cluj si de acolo un tip binevoitor mi lo facut , GRATIS. da cum?
o intrat intr-un program numit AutoData V5.373
o cautat modelul meu dupa caracteristici si an si o scos la imprimanta o foaie cum se face resetarea. avea acolo si scheme grafice cu bordul si toti pasii.
noi nu am putea gasi acest program pe la cineva?
am cautat tot internetu pe google si nu am gasit decat crackuri la el si de unde sa-l cumperi.
ar fi foarte bun cand vrei sa schimbi ceva de exemplu sau sa modifici anumite caracteristici.
BMW Oil Service reset for 2001 ~ current
BMW insp. reset
- Iginition OFF (POS 0)
- Press and Hold the trip odometer button while turning key to position 1 (ACCESSORY)
- Keep the button depressed (about 5 secs.) until you see "Oil Service" or "Inspection" with "Reset" or "Re" in the display
- *Note: On vehicles with "High" cluster, you will also see the amount of fuel (in litres) remaining until next service
- Press the button again and hold for approx. 5 secs. until "Reset" or "Re" flashes
- While the display is flashing, briefly press the button again to reset the Service Interval. After the display has shown the new interval you should see "END SIA" for about 2 secs.
Note that if the "Reset" or "Re" does not flash, then you have not met the minimum consumption level and cannot reset.
BMW insp. reset
61309[/snapback]
merge si pe e39 treaba asta? ca la e46 merge sigur...
