Util- daca intereseaza pe cineva
Am gasit asta (La E46 merge):
Incase no one knows here's how to do it.
Tests 1-2 are unlocked. Tests 1.2, 1.2 etc are known as sub-tests. Tests 3-21 are locked but Test 19 is the unlock function for accessing the displays.This should work with your vehicle.
TEST 01. - Vehicle specific data including:
SubTests:
12345 1.0 = VIN
7504 1.1 = Body number
690151 6_1.2 = Part number of cluster
039000 1.3 = Coding/Diagnosis/Bus Index
1102 1.4 = Manufacturing date (calender week/year)
06_110 1.5 = Hardware/software # of cluster (HW:06, SW:110)
1E5_06 3_1.6 = injection status, number of cylinders, engine factor
TEST 19. LOCK/UNLOCK
Sub-Tests
L-ON---
L-OFF 19.0 =
Displays changes from "L-ON" to "L-OFF" every second. To unlock test functions, press the cluster button immediately when it changes to "L-OFF". Tests are automatically locked when exiting test functions.
TEST 02. - Cluster System Test - activates the gauge drivers, indicators and LEDs to confirm function.
TEST 03. - SI Data
Sub-Tests:
1500 3.0 - Liters
0 3.1 - Periodic inspection days (not applicable for US)
TEST 04. - Momentary Consumption
Sub-Tests:
0267 4.0 = 26.7 liters/1000km
0073 4.1 = 7.3 liters per hour
TEST 05. - Distance Gone Consumptions
Sub-Tests:
0195 5.0 = 19.5 liters/100km
226 5.1 = momentary distance to go (226km)
TEST 06. - Fuel level sensor inputs in liters
Sub-Tests:
237415 6.0 = Fuel level aveg. *LH sensor input = 23.7 liters
*RH sensor input = 41.5 liters
0652 6.1 = Total tank level average = 65.2 liters
0667 1_6.2 = indicated value and tank phase *1 = both sensors OK
*2 = one sensor fault
*3 = implausible input
TEST 07. - Temp. and Speed
Sub-Tests:
032 7.0 = coolant temp. input 32C
245 7.1 = outside temp. input 24.5C
5283 7.2 = engine speed 5,283 RPM
058 7.3 = vehicle speed 58km/H
TEST 08. - Input values in HEX Form
Sub-Tests:
XXX 8.0-8.3 = Hex code, instrument cluster inputs
TEST 09. - Battery Voltage
Sub-Test:
125 9.0 = 12.5v
TEST 10. - Country Coding
Sub-Test
02 10.0 - US 02
TEST 11. - Cluster Code
Sub-Test
000003 11.0 = Cluster Code
TEST 12 - Not Used
TEST 13 - GONG Test
Sub-Test:
Gong 13.0 = Activate gon by pressing buttong (gong response is delayed)
TEST 14. - fault memory (NOT FOR DIAGNOSIS)
TEST 15 to 18
TEST 20. - Averg. fuel consumption - correction factor.
The factor follows previous systems, with adjustment range of 750 - 1250. The adjustment method is new for the base cluster. If adjustment is necessary, enter into test 20 using the cluster button.
The correction factor number is changed by using the sub-tests for the "ones, tens, and hundreds of the correction factor number. The digits will automatically scroll through 0-9 within each group (ones, tens, hundreds).
Sub-Tests:
XXX9 20.0 = Press the button when the correct "ones" position is attained.
XX5X 20.1 = Press the button when the correct "tens" position is attained.
12XX 20.2 = Press the button when the correct "hundreds" position is attained.
TEST 21. - Software reset
sub-test:
reset 21.0 = Reset Software.
  • 9 months later...
Salut FRATILOR, DE 2 SAP AM CUMPARAT UNBMW BREAK DIN 2005, LA CARE Sunt URUIT ONU 60-80 km / h ASA CA DE RULMENT VS CUCIUCURI NOI Desi nu sunt SE Aude PE inundaĂžie neprevĂŁzutĂŁ un apei AM SCHIMBAT (INVERSAT) CAUCIUCURILE SI LA FF fel? AveĂži VRE-O Idee, SFAT, SERVICE ...?
Cel mai bine e sa mergi la un mecanic si sa il iei o tura cu masina, pt ca e cam greu sa explici ce fel de zgomot e si de unde vine....
De fapt e cam greu sa inteleg ce ai scris mai sus..te alearga cineva? :)
Ia-o usurel sa pot intelege si eu. Incearca sa nu mai atingi Caps Lock.
Deci, ce simptom are masina ta?
Salut FRATILOR, DE 2 SAP AM CUMPARAT UNBMW BREAK DIN 2005, LA CARE Sunt URUIT ONU 60-80 km / h ASA CA DE RULMENT VS CUCIUCURI NOI Desi nu sunt SE Aude PE inundaţie neprevăzută un apei AM SCHIMBAT (INVERSAT) CAUCIUCURILE SI LA FF fel? Aveţi VRE-O Idee, SFAT, SERVICE ...?
Frate nu inteleg nimic din ce zici.... Esti arab ?
"... LA CARE Sunt URUIT ONU 60-80 km / h ASA CA DE RULMENT VS CUCIUCURI NOI Desi nu sunt SE Aude PE inundaţie neprevăzută un apei ..... "
SCRISU' MAI SUS SA VADA TOATA LUMEA IN SALA !!!!
.... deci zici ca se aude pe inundatie neprevazuta un apei ?
Cred ca e de la sonda lambda ... :)
cAt E cEasUl ? JOI ? .... Aha , cobor la prima... :lol:
Am fost larocuste dintr-una in-tralta pe de voie la telefon !
Nu ?
Edited by the_rifle
"... LA CARE Sunt URUIT ONU 60-80 km / h ASA CA DE RULMENT VS CUCIUCURI NOI Desi nu sunt SE Aude PE inundaĂžie neprevĂŁzutĂŁ un apei ..... "
Nu ?
Edebitmetrul...
sondeLAmbdA e schimbata miercuri..../
Fantastic
Ce erori avea?
Buna seara! Cum stie cineva opresc Incalzirea oglinzilor vara?
  aveti idee de un serviciu in 3 secunde,
  320d Touring pbmw [/ quote]
  nu se opreste: whistling:: whistling:
  [/ Quote]
am rezolvat-o si p "huruitul cu asta, sper sa ma intelegeti ca ma chinui sa scriu corect, da nu-i ce sunt?: bashwall:
