Boxe MB QUART 469 $ ... merita ?
bimmer4ever
HELP !!!
Merita aceste difuzoare pe e 34 meu? Exista o marca mai buna ?
Astea's 470 $
Technical Specification
* Sensitivity: 90 dB
* RMS Power Range : 80-150 Watts
* Peak Power Handling: 300 Watts
* Frequency response: 35-32000 Hz
Diameter: 6.5 Inch
Features
* 2-way Component Speakers System
* 1" Titanium tweeter
* 6.5" Polypropylene woofer with special coat
* Crossover
* Crossover Frequency 2.400 Hz
* Crossover Slope 12/12 dB/octave
* Impedance: 4 ohms
* A new variation of the WPC process used in QSD is applied here
* Midrange with 37mm (1.5") voice coil is used - Former made of Kapton foil (a temperature resistant plastic) that can withstand extreme heat
* Regardless of the wire size or type you can always connect to an MB QUART. Connection types include solder, screw-down, spade or bare wire.
* Designed specifically for low-profile installations, these die cast aluminium baskets can be installed in factory locations with little or no modification. They are lightweight but extremely rigid.
* BBalanced Temperature Technology is used throughout
* Tweeter level can be adjusted in 2dB steps up to -6dB
* A light bulb is incorporated into the crossover networks to extend the life of the tweeter by protecting it against overloading.
* Tweeter with a 25 mm (1") titanium dome with a highly elastic butyl rubber surround
Sau astea ... HELP !!! Astea sunt 130 $
* RMS Power Range : 50-120 Watts
* Peak Power Handling: 240 Watts
* Frequency response: 40-32000 Hz
Diameter: 6.5 Inch
Features
* 2-way coaxial system
* 0.75" Titanium tweeter
* Impedance: 4 ohms
* Crossover Frequency: 4700 Hz
* Crossover Slope: 12 dB/octave
* The Discus basket combines the advantages of a heat-reflecting metal basket with a low-resonant ABS composite basket.
* Coated speaker cone
* Titanium dome tweeter
* A PTC is incorporated into the crossover network to extend the life of the tweeter by protecting it against overloading.
* Tweeter level can be adjusted in 3 dB steps up to -6 dB
* On board 12 dB crossover
Stiu ca diferenta e mare din toate punctele de vedere intre cele doua variante.
Ce ma sfatuiti ?
salut,
din cate ai specificat boxele sunt chiar valabile,dar sincer eu nu as da asa o caruta de bani pe niste boxe!Sunt pana la urma niste difuzoare.
Iti propun altceva:pe spate 2*boxe ovale 6*9'' pioneer(maxim 100euro),pe fata 2*boxe pioneer 5''(rotunde-maxim 40 euro)+un amplif de 500w(magnat sau ce preferinte ai tu-uita-te la RMS sa aiba min 300w)+un subwoofer jbl (preferabil de 10''-sunt mai mici si difuzorul are o cursa mai rapida)max 100 euro------>>>si in 300 si ceva de euro ai iesit cu o linie audio complexa,linie care-ti astupa si ca fidelitate si ca volum boxele astea MB QUART,parerea mea si sunt sigur a multora :blink:
succes!
stai putin ca nu tre sa decupuzi deloc :blink:
la mine in masina in locul boxelor de fabrica am pus niste boxe de firma acelasi diametru;in carcasa originala a boxelor din spate am vazut ca poti adauga si niste tweetere,deci sonorizarea mediilor + inaltelor e suficienta,bassul fiind asigurat de subwoofer,care poate sa fie activ(adica cu amplif incorporat),si iti spun nu se compara calitatea sunetului daca optezi pt un subwoofer(lada) ca si daca nu ai unul :)
Nu o sa-ti para rau!!!
Nici eu nu ascult cu un bass puternic dar imi place sa se auda mai plin :)
Si mai mult ---NU TRE SA DECUPEZI NIMIC----
Succes
