Resetare RDC - senzor presiune pneuri
Am un E46 2003 cu aceasta optiune. Cand am cumparat-o l-a resetat din tester si s-a aprins iarasi. Vechiul proprietar mi-a spus ca tomai facuse o pana. Din cate am inteles trebuie facuta o setare(resetare) a presiunii rotilor ( asta dupa ce sunt umflate binenteles). Stie cineva cum se face acest lucru?
Am rezolvat singur. Pt cei ce au nevoie de asa ceva:
Initializing the system
Initializing is necessary to familiarize the
system with the correct inflation pressures.
Repeat this process after tire replacement,
tire rotation or any changes in tire
inflation pressure.
1. Check the tire inflation pressures in
all the tires, comparing them with the
inflation pressure chart on page 25
and adjusting their pressure if necessary
2. Turn ignition key to position 2, do not
start the engine
3. Press the button long enough for the
yellow indicator lamp in the instrument
cluster to light up for a few seconds
4. After a few minutes' driving time,
TPM sets the current inflation pressures
in the tires as the target values
to be monitored.
In the event of loss in inflation
pressure
If the inflation pressure has dropped
significantly over a long period of time,
which is normal for any tire, the yellow
indicator lamp will come on.
This alerts you to have the tires inflated
to the specified pressures as soon as
possible.
p.s. RDC e prescurtarea din germana, iar TPM din engleza(tire pressure monitor)
Edited by masinioricestare
  • 5 years later...
inflation pressure.
start the engine
to be monitored.
pressure
possible.
Intrebarea mea e la care buton face referinta la punctul 3?
