BMW E60
alex 83
  • Replies 100
Posted Images
LEt´s see...
- 10 meters of cable - or telephone wire
- 4 diodes
- a torx
- screwdriver
1- start by removing the headlights,
2- remove the drivers "drawer" so you can access the place where the wire is going to go trough, remove the microfilter box
3 - access the headlights housing and conect the wire to the brown a the angel eye pin. The "eyebrow" is conect directly to their pins wich sit on top of the headlight
4- now you need to pass the cable, hide and into the interior of the car (behind the drawer next to the steering wheel)
5- connect the cable into the foot light (if your car has it, if it does not have it you need to direct the cable to the top light)
6 -put your headlights back on
7-hide the wire - or cable
8- close the drawer
9- use the vaccum cleaner (hehehe) to remove the dirt from going in and out of the car
10- and voilĂĄ!
I don´t now how to explain it better!
Sursa:
http://forums.e60.net/index.php?showtopic=54773&st=60 <_<
foarte misto...vreau si eu...
trebuie sa ne intalnim la o lada de bere si 10 m de cablu sa rezolvam problemele <_<
:) nu-i rea ideea, numai sa se mai incalzeasca afara...
Eu aduc diodele....mai am din prima masina cele 6 diode de la alternator...or fi suficiente dpdv al curentului? :bashwall:
