Probleme cu anti-trap la e60
problema este simpla acum daca nu ma insel iti si zic cum se face : deschizi geamul pana jos apoi mentii 5 secunde butonul apasat , apoi inchizi geamul , cand s-a inchis mentii apasat butonul apasat 5 secunde si ar trebui sa dispara , daca nu faci invers .... <_< opresti si pornesti motorul si gata !
sau fa asa:)
Unfortunately, a very common problem on the E60.
Try getting each window to go up and down with the one touch function. One (or more) will stop before going completely up or down. For that window, start in either the fully opened or closed position. Hold the button (don't release) until the window is all the way up (or down)--and hold for 5 more seconds. Then reverse direction with the same procedure. This will reinitialize the window anti trap function.
Schimba motorul de la geam.
S-a rezolvat fara schimbarea motorului,asa cum mi-a spus colegul mai sus
sau fa asa:)
Mersi pentru sfat,a functionat,sper sa nu mai am probleme.bafta multa
