stie cineva daca exista e90 la 512 cp de fabrica?
AR99RMS
E90 este seria 3. Nu stiu ce are asta cu seria 6 in care ai postat.
Seria 6 coupe este E63 si seria 6 cabrio este E64.
Si nu, nu este nici o masina de serie BMW cu 512 CP. E60 M5 si E63 M6 au 507 CP.
77030[/snapback]
oki
mersi si scuze
  • 9 months later...
"Fitted with a modified M5 V10 engine, a 7-speed SMG gear box and the HARTGE modification to raise maximum speed from the electronically limited 250 km/h to 320 km/h, the H50 V10 puts all its power – 550 bhp and torque of 520 Nm (384 lb-ft) – onto the tarmac via a reinforced rear axle and a special suspension setup that is adjustable in terms of both rebound and compression. Also new and made especially for the HARTGE H50 V10, is the stainless steel exhaust system, which turns the V10 sound into an acoustic delight. Customers can choose between two dual round (or oval) tail pipes. The wheel / tyre combination consists of 9 x 20 offset 40 at the front and 10 x 20 offset 40 at the back fitted with 245/30 ZR 20 and 285/25 ZR 20 Continental tyres respectively."
are ...si chiar mai mult
