Resetat
Mircea Pop
Salutari.Am schimbat azi microfiltrul si nu stiu cum sa resetez in calculatorul de bord.Am vazut pe forum indicatii cum sa resetez daca mi s-a aprins indicatorul dar pe mine inca nu m-a atentionat ca trebuie sa il schimb.In luna a 8-a anul acesta zice el sa il schimb dar era murdar si l-am schimbat acum.Cum procedez in acest caz?Modelul este E90.Multumesc anticipat.
Step 1
Insert key into slot
Step 2
Press start/stop button without depressing clutch/brake and wait for the service reminder to dissapear.
Step 3
Immediately after service reminder goes out, press and hold the odometer reset. After 3 secs a warning triangle will appear, keep the odo. button pressed and after another 2-3 secs the Oil can will appear. I f you hold it too long (10 secs in total) you will overshoot the runway and some German writing will appear giving the software level/ can bus etc. of the car. Go back to the beginning and start again.
Step 4
You are now in the service menu, use the toggle switch on indicator stalk to scroll up/down through the various service items.
Step 5
When you have the item you want to reset showing, press the BC button on end of indicator stalk. Reset should now appear in the display. Press in and hold the BC button for 2-3 secs and a clock will start whirling around and hey presto, its done
Step 6
You can now either scroll up/down to select another item (as in step 4) or you can press the start/stop button to exit.
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Care reminder daca inca nu ma atentioneaza ca trebuie sa schimb microfiltrul ci doar peste cateva luni?
Edited by Mircea Pop
