Donatii - daca doriti sa ajutati pe cineva,
donez macara electrica pentru usa soferului. a avut o clema rupta dar am reparat-o eu si zic ca tine fara probleme improvizatia. am apucat sa-mi cumpar alta ca daca stiam ca se poate repara nu mai luam....o foloseam asa. oricum motorasul merge perfect
Macaraua este de pe e46- indiferent daca e facelift sau nu
Edited by ToShiRo
Salut.Va pun la dispozitie bucsa semicaseta de directie noua(nefolosita) FEBI BILSTEIN pt BMW e34.Este vb de piesa nr.15 de pe prima poza.Se potriveste si pe urmatoarele modele:
Part Cross-reference
RealOEM.com Home
Language: 32211136452 (Rubber Mounting) was found on the following vehicles:
E24: Details on E24
E24 628CSi Coupe, Europe
E24 635CSi Coupe, Europe
E24 M635CSi Coupe, Europe
E28: Details on E28
E28 518i Sedan, Europe
E28 520i Sedan, Europe
E28 524d Sedan, Europe
E28 524td Sedan, Europe
E28 525e Sedan, Europe
E28 525i Sedan, Europe
E28 528i Sedan, Europe
E28 535i Sedan, Europe
E28 M5 Sedan, Europe
E28 M535i Sedan, Europe
E31: Details on E31
E31 840Ci Coupe, Europe
E31 840i Coupe, Europe
E31 850Ci Coupe, Europe
E31 850CSi Coupe, Europe
E32: Details on E32
E32 730i Sedan, Europe
E32 730iL Sedan, Europe
E32 735i Sedan, Europe
E32 735iL Sedan, Europe
E32 740i Sedan, Europe
E32 740iL Sedan, Europe
E32 750i Sedan, Europe
E32 750iL Sedan, Europe
E32 750iLS Sedan, Europe
E34: Details on E34
E34 518g Touring, Europe
E34 518i Sedan, Europe
E34 518i Touring, Europe
E34 520i Touring, Europe
E34 520i Sedan, Europe
E34 524td Sedan, Europe
E34 525i Sedan, Europe
E34 525i Touring, Europe
E34 525td Sedan, Europe
E34 525td Touring, Europe
E34 525tds Sedan, Europe
E34 525tds Touring, Europe
E34 530i Sedan, Europe
E34 530i Touring, Europe
E34 535i Sedan, Europe
E34 540i Sedan, Europe
E34 540i Touring, Europe
E34 M5 Touring, Europe
E34 M5 3.6 Sedan, Europe
E34 M5 3.8 Sedan, Europe
E38: Details on E38
E38 725tds Sedan, Europe
E38 728i Sedan, Europe
E38 728iL Sedan, Europe
E38 730d Sedan, Europe
E38 730i Sedan, Europe
E38 730iL Sedan, Europe
E38 735i Sedan, Europe
E38 735iL Sedan, Europe
E38 740d Sedan, Europe
E38 740i Sedan, Europe
E38 740iL Sedan, Europe
E38 740iLP Sedan, Europe
E38 750i Sedan, Europe
E38 750iL Sedan, Europe
E38 750iLP Sedan, Europe
E38 750iLS Sedan, Europe
E38 L7 Sedan, Europe
E39: Details on E39
E39 535i Sedan, Europe
E39 540i Touring, Europe
E39 540i Sedan, Europe
E39 540iP Sedan, Europe
E39 M5 Sedan, Europe
Prefer sa o dau la cineva din Cluj din cauza deranjului cu curierul dar daca nu se anunta nimeni pot sa o trimit si in tara pe cheltuiala voastra.
Guest poleposition
donez far M6/Seria 6 (presupun ca sunt la fel) dynamic xenon (adaptive light)
la mine se aburea, l-am schimbat cu totul, nu am stat sa vad de ce se aburea de fapt.... nu are urechile rupte sau ceva.
daca il vrea cineva, PM.
as vrea eu macaraua daca se poate. zi-mi sa-ti trimit pe PM datele/ mersi
vezi ca ti-am pus pachetul
am platit eu si transportul, dar nu-i bai, dai o bere daca vre-o data ne vom intalni <_<
bafta
multumesc foarte mult. esti un domn. cu prima ocazie iti promit ca-ti dau cateva beri :) vino pe la tm ...
RealOEM.com Home
E24: Details on E24
E28: Details on E28
E31: Details on E31
E32: Details on E32
E34: Details on E34
E38: Details on E38
E39: Details on E39
sal,
o vreu eu; daca nu se gaseste nimeni prin cj.
deci, daca nu sunt doritori prin cj. poat eajunge la buc.?
donez 4 amortizoare toate originale de pe masina mea 320 dA 2000 pentru ca eu le-am schimbat. cuprind si aparatori si flanse. In plus mai dau si bieletele antiruliu. Nu stiu cat de uzate sunt eu le=am schimbat ca sa fie. Numai Bucuresti sau Buzau.
m-ar interesa pe mine
0766 75 75 72
0766 75 75 72
s-au dat sry
