schimbat grade
Am gasit:
"you can change the units of measure(F/C) for the outside temperature display by:
1)pressing and holding the trip odometer reset button(in ignition key position 1)
2)and then turning the ignition key to 0."
Edited by CC23298
"Poti schimba afisarea unitatii de masura (F/C) a temperaturii exterioare astfel:
1/ apasand si tinand apasat butonul odometrului de calatorie (cu cheia in pozitia 1)
2/ intorcand apoi cheia in pozitia 0"
