DVD Auto belson bs3000
cel mai probabil ca ai conector iso, daca da, trebuie sa arate la fel ca si cel din poza, cel putin slotul A si B, daca da, asta e...
SLOT A
# Pin 1 - speed-dependent volume control.
# Pin 2 - mute control .
# Pin 3 - the reversing light switch. (for navigation systems)
# Pin 4 - permanent +12v input to the radio from the battery, already in the DIN radio harness.
# Pin 5 - automatic aerial - +12v output from the radio, maximum 150mA, to drive an automatic or electronic aerial.
# Pin 6 - illumination - +12v input to the radio when the car's lights are on.
# Pin 7 - ignition - +12v input to the radio when the ignition is on.
# Pin 8 - chassis ground
SLOT B
# Pin 1 - Right rear speaker +
# Pin 2 - Right rear speaker -
# Pin 3 - Right front speaker +
# Pin 4 - Right front speaker -
# Pin 5 - Left front speaker +
# Pin 6 - Left front speaker -
# Pin 7 - Left rear speaker +
# Pin 8 - Left rear speaker -
in afara de iso mai ai probabil RCA video IN+OUT
succes!
am fost la beloud...prima oara cu el ... si m-au tratat k pe un client oarecare ...."N-avem domne!Nu gaseshti!" ... au uitat k le-am bagat 600e intr-o noapte pe neshte chestii ///Alpine ...
o sa fac si o poza ... la mufa...poate ma ajuta cineva sa fac mufele pe direct .... fac masa mare ....dak ma ajuta careva...
