cumpar urgent un litru ulei bmw 10w 40
In general uleiurile pot fi amestecate, atata vreme cat e vorba de sintetic cu sintetic, semisintetic cu semisintetic si mineral cu mineral si caracteristicile sunt similare.
Cel mai bine este sa urmezi recomandarile producatorului. In acest caz ai noroc :) .
Castrol chiar spune despre Magnatec ca poate fi amestecat fara probleme cu alte tipuri de ulei, chiar destul de diferite :
Will Castrol Magnatec mix with the oil I am currently using?
Castrol Magnatec is specially designed to mix completely with other synthetic, part synthetic or mineral lubricants. Not only is it OK to top up with Castrol Magnatec but you will begin to benefit straight away from the active and continuous protection from it’s Intelligent Molecules, reducing engine wear caused by inferior oils.
