ciudatenie la business CD
SadRocko
Am cautat peste tot pe forum si nu am gasit pe nimeni ca sa fi postat asa ceva. Ma explic: ieseam cu masina din tara, mergea plyerul pe CD mode. La 300-500 m de granita se opreste CD-ul si imi aud urechile ceva in ungureste, un mesaj de vreo 15 secunde(nu stiu limba, nu am inteles nimic). Am crezut ca a sarit cd-ul si a intrat radioul pe ceva post unguresc. La 200-300 m dupa granita acelasi lucru. Nevasta imi zicea ca sare cd-ul(as fi inteles la noi in tara, dar la unguri drumul era deja lins).
La intorcere acelasi lucru si inainte si dupa granita. Parca semanau intre ele mesajele alea, vocea sigur era aceeasi. banuiesc ca era ceva mesaj de bun venit si eventual o precizare legata de regulile lor de circulatie.
Vreau sa inteleg cum e posibil asta din moment ce eu am doar business cd fara navigatie si alte module.
masina este e46 320d octombrie2003
Traffic Announcement (TA) refers to the broadcasting of a specific type of traffic report on the Radio Data System. It is generally used by motorists, to assist with route planning, and for the avoidance of traffic congestion.
The RDS-enabled receiver can be set to pay special attention to this TA flag and e.g stop the tape/pause the CD or retune to receive a Traffic bulletin. The related TP (Traffic Programme) flag is used to allow the user to find only those stations that regularly broadcast traffic bulletins, whereas the TA flag is used to stop the tape or raise the volume during a traffic bulletin.
On modern units, traffic reports can also be recorded and stored within the unit, both while the unit is switched on, but also for a pre-set period after the unit is turned off. It may also have in-built timers to seek and record the same for two separate daily occasions, ie, one setting for before the morning commute, and the second for the evening return journey. These messages may then subsequently recalled on demand by the driver. This specific function is known as TIM, or Traffic Information Message.
Aveai aceasta functie activata.Ai un buton TP langa butonul RDS acesta avand o steluta in dreapta lui semn ca este activ.
Edited by Taz
