Valabil pt DDE 5/5.1
1 Preheating
At coolant temperatures below 25°C, there is a preheating period of 0.5 seconds. The preheating period increases as the temperature falls, reaching a maximum of 2.7 seconds at a coolant temperature of less than -25°C.
Activation of the glowplug system on the instrument cluster only occurs at coolant temperatures below 0°C.
2 After-heating
At coolant temperatures below 30°C, there is a temperature-dependent after-heating period to improve idling and exhaust emission characteristics.
3 Start preheating
Start preheating takes place for approx. 10 seconds if after the preheating time has elapsed the engine is not started and the ignition remain on."
DDE 5/5.1 Ro
1 Preincalzirea
Cand temp. apei de racire motor este sub 25°C bujiile sunt activate pt 0.5s. Timpul creste cu scaderea temperaturii ajungand pana la max 2.7s cand temp. apei e sub -25°C
Avertizarea pe bord apare doar cand temperatura apei ajunge sub 0°C
2 Dupa preincalzire (adica dupa ce motorul e pornit)
Cand temp. apei e sub 30°C, activarea si perioada de activare a bujiilor e dependenta de temperatura apei si se foloseste pt a mentine turatii cat mai constante la relanti si pt a scadea emisiile.
3 Preincalzirea pt pornire
Functia dureaza aprox 10s si se activeaza daca timpul pt preincalzire a trecut (se refera la cele "max 2.7s" ) motorul nu e pornit si cheia ramane pe accesorii.
Preheating System DDE 4.0
1 Preheater time control
The preheating duration is dependent on the engine coolant temperature and battery voltage and is indicated by the preheating/DDE indicator.
2 Preheating
At temperatures below 5 °C, preheating takes place for at least 4 seconds. The preheating time increases as the temperature decreases.
3 After-heating
After-heating takes place after engine start at temperatures below 20 °C in order to improve idle and exhaust characteristics.
4 Start preheating
DDE 4.0 Ro
1 Controlul timpului de activare
Durata activarii bujiilor depinde de temperatura apei de racire si tensiunea bateriei si este indicata de catre un martor sau mesaj
3 Preincalzirea
Are loc la temperaturi sub 5 °C, si dureaza cel putin 4s. Timpul creste cu scaderea temperaturii.
3 Dupa preincalzire
Functia se activeaza dupa ce motorul e pornit la temperaturi sub 20 °C pt a mentine turatiile cat mai constant la relanti si pt a scadea emisiile
4 Preincalzirea pt pornire
Functia dureaza aprox 10s si se activeaza daca timpul pt preincalzire a trecut (se refera la 4s) motorul nu e pornit si cheia ramane pe accesorii.
Preheating System DDE 3.0
2 Preheating
Preheating takes place for approx. 2 seconds between 6 °C and 20 °C. No preheating takes place at temperatures above this value.
3 After-heating
After-heating takes place after engine start at temperatures below 40 °C in order to improve idle and exhaust characteristics.
DDE3 Ro
2 Preincalzirea
Are loc la temperaturi intre 6 °C si 20°C si dureaza aprox 2s. Functia nu se activeaza la temperaturi mai ridicate.
3 Dupa preincalzire
Functia se activeaza dupa ce motorul e pornit la temperaturi sub 40 °C pt a mentine turatiile cat mai constant la relanti si pt a scadea emisiile
asa ca nu doar iarna se folosesc bujiile la diesel :lol:
sa va fie de folos :)
Edited by clauberty
