statie radio
prepe87
Cati wati are?
Channels Refer to programmed band
Modes (AM, FM) Refer to programmed band
Operating Temp. -10°/+55°C
DC Input Voltage 13.2Vdc ±15%
Size 180(L) x 50(H) x 153(D) mm
Weight 1 Kg
TRANSMITTER
System CPU Controlled PLL
Synthesizer
Max Output Power 4W at 13.2Vdc
Modulation AM (from 85% to 95%)
FM (1.8 KHz ±0.2 KHz)
Output Impedanced 50 Ohm unbalanced
Current Drain 1100 mA (at no modulation)
RECEIVER
System CPU Controlled Double
Conversion Super
Heterodyne
IF 1° 10.695 MHz / 2° 455 KHz
Sensitivity 0.5µV for 20dB SINAD (FM)
0.5µV for 20dB SINAD (AM)
Audio Output Power @10% THD 2.5W at 8 Ohm
Audio Distorsion <8% at 1 KHz
Image Rejection 65dB
Adjacent Ch. Rejec. 65dB
Signal/Noise Ratio 45dB
Current Drain 250mA (stand-by)
  • 2 years later...
