resetare placute frana x6
Guest eueugen
Step 1
Insert key into slot
Step 2
Press start/stop button without depressing clutch/brake and wait for the service reminder to dissapear.
Step 3
Immediately after service reminder goes out, press and hold the odometer reset. After 3 secs a warning triangle will appear, keep the odo. button pressed and after another 2-3 secs the Oil can will appear. I f you hold it too long (10 secs in total) you will overshoot the runway and some German writing will appear giving the software level/ can bus etc. of the car. Go back to the beginning and start again.
Step 4
You are now in the service menu, use the toggle switch on indicator stalk to scroll up/down through the various service items.
Step 5
When you have the item you want to reset showing, press the BC button on end of indicator stalk. Reset should now appear in the display. Press in and hold the BC button for 2-3 secs and a clock will start whirling around and hey presto, its done
Step 6
You can now either scroll up/down to select another item (as in step 4) or you can press the start/stop button to exit.
Sorry if this a re-post guys but like I said I couldn`t find it anywhere.
I accept no responsibility if you break your car, this is done at your own risk.
Este pentru ulei,dar e cam acelasi lucru
Guest eueugen
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
ms....o sa incerc....
Guest eueugen
La E92 a functionat.Nu cred ca e diferenta la X6,ar trebui sa mearga.
Nici uleiul nu l-ai putut reseta?
Senzorul de la placute l-ai schimbat?
nici uleiul nu a mers.
da senzori sunt schimbati.
