320i e36 vs 320i e46
SilviuSLV
  • Replies 225
Posted Images
Motoarele sunt identice.Au acelasi cuplu si aceeasi putere.Vorbim de motoarele M52.Si spre deosebire de ce cred majoritatea .. paradoxal E46 este mai usor decat E36 :) Iata si datele masinilor : :)
BMW E36 320i
(1994 - 1998)
Engine : I 6
Engine Code : M52B20
Fuel : Petrol
Fuel System : Siemens DME MS41.0
Engine Alignment : Longitudinal
Drive : RWD
Displacement : 1991 cm3
Bore x Stroke : 80 x 66 mm
Type : 24 Valves
Aspiration : N/A
Compression Ratio : 11
Output : 150 cv (110 kW) @ 5900 rpm
Torque : 190 Nm (140 lb.ft) @ 4200 rpm
Gearbox : 5 speed Manual
Wheelbase : 270 cm
Length : 443.3 cm
Width : 169.8 cm
Height : 139.3 cm
Cx :
Front Brakes : Vented Discs (286 mm)
Rear Brakes : Discs (280 mm)
Front Tyres : 205/60 R15
Rear Tyres : 205/60 R15
Kerb Weight : 1375 kg
Weight/Output Ratio : 9.17 kg/cv
Front Suspension : McPherson struts
Rear Suspension : Multi-Link Z-Axle
Top Speed : 214 km/h (133 Mph)
0 to 100 km/h : 9.9 s
0 to 400m (1/4 mile) : s
0 to 1000m : 30.7 s
BMW E46 320i
(1998 - 2000)
Engine : I 6
Engine Code : 20 6S 4
Fuel : Petrol
Fuel System : MPI - Siemens Motronic MS42.0
Drive : RWD
Bore x Stroke : 80.0 x 66.0 mm
Type : 24 Valves
Aspiration : N/A
Compression Ratio : 11.0
Torque : 190 Nm (140 lb.ft) @ 3500 rpm
Wheelbase : 272.0 cm
Length : 447.0 cm
Width : 174.0 cm
Height : 142.0 cm
Cx : -
Rear Brakes : Vented Discs (276 mm)
Front Tyres : 195/65 R15
Rear Tyres : 195/65 R15
Kerb Weight : 1365 kg
Weight/Output Ratio : 9.1 kg/cv
Front Suspension : Independent. McPherson. coil springs. anti-roll bar
Rear Suspension : Multilink. Coil springs. anti-roll bar
Top Speed : 219 km/h (136 Mph)
0 to 400m (1/4 mile) : - s
0 to 1000m : - s
Fuel Consumption* : 6.8L / -L / 12.5L / 8.9L (26 mpg)
BruceLee il bate pe VanDamme? :lol:
Edited by Boxer
nu stiu de unde ai luat datele despre masini dar iti recomand AutoData si o sa vezi ca e36 e mai usor decat e46. si nu inteleg de ce se dezbate asa intens subiectul ca pana la urma urmei totul de rezuma la 402 m si la stilull de "condus" al participantilor. Si mai vroiam sa zic apropo de datele alea sunt putin improprii pt ca depinde de modelul de caroserie a fiecarei masini. (cabrio fiind f greu,, break-ul de asemenea) asa ca nu stiu datele daca se refera la acelasi tip de caroserie.
Este vorba de sedan.Vorbesc de motorul M52 cum am precizat si in primul post :) nu de motorul M50 care a fost pus pe e36 pana in '94.
oricum datele tehnice din hartoage nu sunt chiar un factor decisiv...experientele traite cu masina respectiva pot fii foarte diferite decat pe hartie...spre exemplu scrie acolo 0-100 9.9s...poate odata cineva scoate 9.7 sau 10.3...zic si eu, nu poti sa bagi mana in foc ca masina e exact cum o descriu datele tehnice, ca asa poate oricine sa se uite pe net si nu ar mai fii nevoie nici de forum, nici de topicul asta, dar lumea aici intreaba pentru a afla cat mai exact, pentru a invata din fapte reale, concrete
si daca masina mea scoate 9.9 ...eu o mananc !
De acord cu tine.Sa tinem cont de faptul ca,conteaza foarte mult jantele si gumele.Daca ai jante pe 15 cu gume de 195 sigur vei avea o acceleratie mai buna decat pe jante de 17 cu gume e 235.De asemenea depinde si de tipul anvelopelor si de "rezistenta la inaintare" pe care acestea le au.Sunt multe de discutat pe aceasta tema :)
PS Sursa detaliilor tehnice pe care le-am prezentat mai sus este www.ultimatespecs.com
Edited by Boxer
oricum nush dc...dar detaliile tehnice de pe site`uri de la 320i nu corespund cu realitatea...incepand cu greutatea si sfarsind cu 0-100:)
De ce spui asta?
Care sunt valorile reale?
pai spre exemplu...un 320d 150 hp...are 0-100..in 8.9....cum se poate ca eu 320i...am facut 2 320d...0-100....un audi a4 2.5 quattro 180 hp eram la egalitate....si un a4 2.5 tdi 163 hp..il alerg :)
ala de pe audi 2,5 tdi quatro inseamna ca fuma cu o mana, iar cu cealalta se m....ba, din moment ce ai stat cu 320 in fata lui. sau poate omul mergea la consum si tu te fortai sa il depasesti.
cat rau poate sa creeze nfs-ul jucat la varste inaintate
Edited by mihai20
De ce spui asta?
pot sa va zic ca eu cu 318is am facut si e46 320d si e46 320 benzina...
:) :lol: :) rar topicuri atat de hazlii :) chiar asteptam un 318 sa spuna ca bate tot ce misca
acum tre sa vina un 316 care sa bata 318-le, si uite asa ne dam seama cu totii cat de fraieri suntem sa cumparam masini de 150-200-250 de cai, ca pana la urma, din aproape in aproape, tot ala cu 100 de cai e cel mai smecher
astept cu nerabdare 316-le care rupe pe genunchi 318, imposibil sa nu apara
ce fraieri astia cu m3, ca sigur un 320 condus de un viteaz il bate grav.
de aia de la audi nici nu mai vb, ca toti au trait in copaci , si ca un audi sa bata un bmw ii trebuie putere cel putin dubla.
rs4 ala de 400 si ceva de cai abia se apropie de 330i .....iar daca era diesel 330, sigur il bateam si la viteza de top, ca dieselul se intinde mai bine la drum
