E46-mici secrete
zixx
pt cass, trage fir direct de la plus-ul de sub capota
47188[/snapback]
E aberant sa t kinui cu un fir de la plusul bateriei.
E suficient doar sa faci un strap pe mufa care-ti baga firele in cas si sa unesti plusul de contact cu plusul permanent. Cu un multimetru le poti identifica foarte usor.
51452[/snapback]
ai dreptate, e mult mai simplu, nu m-am gandit, ma bad :blink:
1. nici mie nu porneste
2. la mine o opresc inainte..si cand dau contact... imi pleaca pe cea mai de jos turatie.. o deschideeeeeee minim !
47253[/snapback]
Ambele chestii (sistem sunet fara contact si restaurare on/off clima) au fost introduse la E46 de la facelift (2002).
55393[/snapback]
am constatat si eu asta la masina unui prieten, el are modelul cu facelift...
Edited by aleks
RESET OIL SERVICE INDICATOR
OK, am mai pus-o pe un post, ca reply la o intrebare, dar o pun si aici pentru ca se pare ca pe topicul asta isi are locul :blink: Nu am incercat-o inca, aparent la mine nu am ajuns la acel "minimum consumption level". Poate ne zice cineva daca merge.
No need for reset tool for 2001+ model
BMW insp. reset
- Iginition OFF (POS 0)
- Press and Hold the trip odometer button while turning key to position 1 (ACCESSORY)
- Keep the button depressed (about 5 secs.) until you see "Oil Service" or "Inspection" with "Reset" or "Re" in the display
- *Note: On vehicles with "High" cluster, you will also see the amount of fuel (in litres) remaining until next service
- Press the button again and hold for approx. 5 secs. until "Reset" or "Re" flashes
- While the display is flashing, briefly press the button again to reset the Service Interval. After the display has shown the new interval you should see "END SIA" for about 2 secs.
Note that if the "Reset" or "Re" does not flash, then you have not met the minimum consumption level and cannot reset.
56482[/snapback]
merge sigur, am reusit eu... poate nu chiar asa cum ai spus tu, dar ceva combinatie de genul asta. cautand pe net, am gasit mai multe solutii, toate foarte asemanatoare. multi spuneau "trial and error", adica reuseau in cele din urma dupa cateva incercari, fara sa poata preciza apoi foarte exact succesiunea pasilor. asa a fost si la mine :blink: m-am tot jucat cu butonasul ala, pana mi-am resetat chestiunea fara sa vreau :)
56484[/snapback]
si eu am reusit la al meu (E46- 2000 iunie modelul 316i) dar nu stiu cum exact... :) merge sigur intr-o anumita ordine...
eu am resetat oil inspection dupa procedura descrisa insa mi s'a resetat la 22.000km. e normal ?? sa inteleg ca exista un picutz de uzura ?
56524[/snapback]
Ar fi cam aberant... Adica continua sa contorizeze si sub limita, si ti-o scade din intervalul urmator? Reducand la absurd sa zicem ca mergi 50.000 fara sa resetezi (schimbi la 25.000 fara reset), dupa aia schimbi si la reset zice... zero? Adica mai schimba-l o data?
Poate 22.000 e pentru motorul ala intervalul? Asta tu treb sa stii mai bine, daca s-a resetat vreodata la dealer...
Totusi, ca tot veni vorba, s-ar potrivi cu realitatea? Adica nu l-ai resetat cand ai facut ultimul schimb acum 1-2 mii km?
deci masina o am din germania ... a avut revizia facuta acolo, a venit aici i'am facut revizia, inspectia a fost resetata cu un dispozitiv d'ala de resetat ... tot la 22mii s'a resetat.... am facut schimbul acu vreo 300-400km si apoi m'am uitat aici de procedura.... am resetat si oil service 22mii km :blink: so .....
asa se reseteaza si la voi ???
oricum nu mai stau 22mii pana la schimb ulei..... de acum mi'am propus sa'l schimb la 10-15mii km .... eu zic ca e mai mult decat ok !!
oricum ca vine iarna nu o sa mai facu mii de km aiurea si cred ca o sa fac schimbul candva in vara cand am planuit un tur micutzzzz prin europa, dak o vrea Domnu' :)) ( na ca o dau pe credinta ) :))
Edited by oSerX
56587[/snapback]
Interesant, deci se pare ca sunt diferente intre 4 cilindrii benz si 6 cilindrii benz, respectiv la 4 cil e 22.000. Eu am 325 (6 cil) si mi se reseteaza la 25.000.
56587[/snapback]
Stai linistit ca nu o sa o faci la 22.000 reali - o sa vezi ca nu scade km pe km, ci mai repede. Variaza enorm dupa stilul de condus. A mea isi cere schimbul pe la 12-15.000 reali in loc de aia 25.000. Eu zic ca poti linistit sa faci schimbul dupa calcului masinii, cu conditia sa bagi ce trebuie in ea. Eu de ex. iau uleiul de la BMW, acelasi indif de vara sau iarna (parca e 5w40, nu bag mana-n foc insa, pot sa ma uit in garaj daca vrei). Scrie BMW pe el da' e facut OEM de Castrol, unii zic ca ar avea niste aditivi speciali pt. BMW altii ca nu. Mie mi-a fost suficient sa vad cat de curat e uleiul la 10.000 reali (chiar curat!) ca sa ma conving ca e bun si ca pot sa las masina sa faca socoteala. Edited by mchis
56619[/snapback]
am intrebat la reprezentanta la brasov, si mi-au spus ca motoarele sunt motoare "inteligente", si ca nu e bine sa le faci schimbul mai devreme de indicatia de pe bord.
si intr-adevar, nu sunt k reali, scad mai repede in functie de stilul de condus
56644[/snapback]
La ulei chestia cu "nu e bine" eu zic ca e prea mult spus. Parerea mea e ca mai des sunt bani aruncati si atat. Cu altele, gen filtru de carburant, e alta poveste insa...
56644[/snapback]
De motor inteligent nu am mai auzit.Cred ca este ceva nou :blink:
Cred ca este foarte indicat sa schimbi uleiul mai repede, mai ales daca se merge mult cu masina in oras.
Probabil ca exprimarea mecanicului a fost un pic pitoreasca. Ideea pe care cred ca voia sa o transmita era ca printre altele, computerul de bord calculeaza intervalul de km pana la revizie tinand cont de mai multi factori, nu numai de km efectivi.
56678[/snapback]
In afara de modelele care au un senzor de calitate al uleiului,calculul este facut pe baza consumului de carburant si de timp.Daca vrei sa schimbi uleiul mai devreme(pe la 10000km) nu vad cum ar afecta ...inteligenta motorului :blink:
Hai sa va intreb ceva. Ca vad ca Mchis deja a raspuns. Care e diferenta intre km pana la revizie calculati si cei care ii arata computerul de bord?
Ca va zic una, nu o sa ma credeti: m-am uitat acum sa fac diferenta, si la 15.083 km parcursi imi arata interval de service pana la schimbare ulei de 15.800 km. Vedeti ce cuminte merg?
56789[/snapback]
Diferenta?La ce te referi?
Dupa schimbul de ulei,urmeaza inspectia.Se calculeaza la fel ca la schimbul de ulei.
Nu se analizeaza placutele de frana,filtrul de polen..etc ca la seria 5 si 7.
