E46-mici secrete
zixx
Diferenta?La ce te referi?
Dupa schimbul de ulei,urmeaza inspectia.Se calculeaza la fel ca la schimbul de ulei.
Nu se analizeaza placutele de frana,filtrul de polen..etc ca la seria 5 si 7.
56875[/snapback]
Pai ma refer la faptul ca suma km. parcursi si a indicatiei de la bord e mai mare de 30.000 km!
  • 4 months later...
RESET OIL SERVICE INDICATOR
OK, am mai pus-o pe un post, ca reply la o intrebare, dar o pun si aici pentru ca se pare ca pe topicul asta isi are locul :blink: Nu am incercat-o inca, aparent la mine nu am ajuns la acel "minimum consumption level". Poate ne zice cineva daca merge.
No need for reset tool for 2001+ model
BMW insp. reset
- Iginition OFF (POS 0)
- Press and Hold the trip odometer button while turning key to position 1 (ACCESSORY)
- Keep the button depressed (about 5 secs.) until you see "Oil Service" or "Inspection" with "Reset" or "Re" in the display
- *Note: On vehicles with "High" cluster, you will also see the amount of fuel (in litres) remaining until next service
- Press the button again and hold for approx. 5 secs. until "Reset" or "Re" flashes
- While the display is flashing, briefly press the button again to reset the Service Interval. After the display has shown the new interval you should see "END SIA" for about 2 secs.
Note that if the "Reset" or "Re" does not flash, then you have not met the minimum consumption level and cannot reset.
56482[/snapback]
La mine a mers fara probleme exact cum e explicat aici. BMW 316i 2001 (fara face-lift, motor 1.9). Mi s-a resetat la 25.000
LA MINE fara cheie doar lumina din habitaclu merge ... nici macar luminile alea pt fiecare persoana in parte nu merg .....
47802[/snapback]
La fel si la mine dupa ce scot cheia din E46-sele meu din 2000 dar mai e ceva:chiar daca e scoasa cheia din contact, daca imping de maneta de semnalizare in fata atunci mi se aprinde pozitia si faza scurta...oare e normal???
OK, am mai pus-o pe un post, ca reply la o intrebare, dar o pun si aici pentru ca se pare ca pe topicul asta isi are locul :) Nu am incercat-o inca, aparent la mine nu am ajuns la acel "minimum consumption level". Poate ne zice cineva daca merge.
BMW insp. reset
56482[/snapback]
bine ca eu am dat una suta mii lei sa-mi rezolve careva asta...si nici nu mi-a aratat :blink:
98011[/snapback]
e lumina de insotire, park asa s numeste
rmane vreo 2 minute cred aprinsa
eu parkez uneori noaptea in fatza blocului
si dau flash
ramane aprinsa
plec, si se stinge dupa o perioada singura, dar p mine ma ajuta sa ajung in bloc :blink:
tragi o data de maneta ... si ramana aprinsa vreo cateva zeci de secunde ... unde aceste cateva zeci de secudne le poti seta la service la diagnoza ....
si daca se pune semnal stanga sau dreapta ... cu cheile scoase... se aprind pozitiile pe stanga sau pe dreapta .. pt a semnaliza prezenta ta pe acolo :blink:
98228[/snapback]
asa-zisa functie "follow me home" de la alti producatori... foarte tare - nu stiam :blink:
am gasit-o si eu - nu se stinge daca trag de maneta la loc, ci doar daca aprind si sting farurile/pozitia de la comutator...misto chestie... :)
mai vreau din-astea!
Am verificat si eu aseara...si s-a stins pana am ajuns in scara...cred ca sta cam 1 minut aprinsa. Stiam de chestia asta dar n-am avut niciodata rabdare sa o las sa se stinga singura  :) dar noroc ca mi-ati zis voi
98436[/snapback]
eu m-am speriat k am vreun scurt ceva in garaj cand am dat peste maneta intr-o seara...
(nu ma intrebati c faceam in masina la ora aia si cu cine de am dat peste maneta k nu va spun :blink: :) )
oricum, nu m-am oprit sa vad c are si s-a stins singurica, si atunci am descoperit minunea :) :D
98228[/snapback]
Merge si la xenon?
  • 4 months later...
in consola centrala, sub cotiera, in compartimentul acela acoperit de capacul acela ca o "prelata" de plastic care se ruleaza am un fel de mufa de plastic cred, pe peretele stang al compartimentului. Ce face? :blink: Aia e pentru OBD?
157593[/snapback]
Acea mufa este de fapt, un suport pt. "PIX" , :) , mai are si un suport pt. carte de credit sau alt tip de card... in partea dreapta (lateral) daca nu ma insel...
