E46-mici secrete
zixx
sal.merge si la xenon.este de mare ajutor cand parchezi undeva unde nu este pic de lumina.. :blink:
158024[/snapback]
foarte tare skema. nici nu stiam. si mie imi merge si ma mir cum de in 2 ani de cand am E46 cum naiba de nu am tras nici macar o data din greseala de maneta aia cand era skoasa cheia din contact.
158026[/snapback]
:) Am tras eu de ea, din greseala.... chiar cand am luat masina.... crede-ma am stat o jumatate de zi sa-mi dau seama ce facusem... :) ... dupa o saptamana am aflat si eu de chestia asta... :blink:
Instructions to access the hidden OBC functions:
1. Hold Trip Reset while turning ignition key to on position
2. OBC should show "Test"
3. Use Trip Reset to select function 19.0 that unlocks all the features
3. Wait for display to show "Off"
4. Depress Trip Reset for 1/4 second and release it
5. With no delay press Trip Reset several times to select one of the following function s
BMW E46 On-Board Computer (OBC) Hidden Codes
nr example description
1 Car Engine and cluster data
1.0 46nnn Chassis nr/VIN serial number (last 5 digits)
1.1 4nnn K-number
1.2 690236 Cluster Part #
1.3 045210 Coding (04)/diagnosis (52)/bus index (10)
1.4 1200 Week (12)/year of manufacture (2000)
1.5 09_160 Hardware (09) and software # (16.0) of cluster
1.6 Not used
1.7 04__44 CAN-version (04) KI-revision index (44)
2 (test) Cluster System Test - Activates the gauge drivers,
indicators and LEDs to confirm function
3 SI Data
3.0 1098 Used fuel in liters since last SI (Service Inspection)
3.1 0231 Periodic inspection days; elapsed days (since last SI)
4 Momentary Consumption
4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km
4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour
5 Distance Gone Consumption
5.0 082 Average mileage; 082=8.2 liters/100km
5.1 0536 Calc. km to refuel (momentary distance to go)
6 Fuel Level sensor inputs in liters
6.0 109330+ Fuel level averaged; Left half sensor input=10.9 liters; Right sensor input=33.0 liters
6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9 liters
6.2 0442+ Indicated value (44.2) and tank phase
7 Temperature and Speed
7.0 021+ Coolant/Engine temperature (2.1C)
7.1 130 Ambient/Outside temperature - chg met 5 pts. 125/130/135
7.2 + Engine speed / Current RPMs 1/min
7.3 + Vehicle speed / Current Speed in km/hour
8 Input value in HEX form
8.0 1d0+ System voltage ADC-Value Hex code
8.1 26C33C+ ADC Values HG left/HG right
8.2 0000 ADC Value brake degradation sensor (000=o.k.)
8.3 18C ADC Value outside temperature
9 Battery
9.0 140 Battery Voltage - 140 = UB 14.0v
9.1 242013+?
9.2 074_78+?
9.3 0011+?
10 Not used
11 Not used
12 Not used
13 GonG Gong Test
14 Not used
15 Status cluster I/O-ports (bit codes) 0=low; 1=high
1st-belt contact, seat belt fastened=0; 2) ignition lock contact, key inserted=0; 3) door contact, door open=0; 4) clock button pressed=0; 5) SI reset=0, for reset=0; 6) EGS transmission failure=0
Status Digital Outputs (bits) 0=inactive, 1=active
1) Gong output; 2) Brake warning lamp; 3) Low fuel warning lamp; 4) EGA lamp; 5) seat belt lamp; 6) manipulation dot
16 Not used
17 Not used
18 Not used
19 Lock Status; unlocks functions in range 3-18
19.0 L-On/L-Off Unlock: press button when "L-Off"
20 Not used
21 Software Reset; reset OBC settings
00 End of test
multumiti? :blink:
2 intrebari am si eu legat de un E46.
1. Ce se intampla daca tin mai mult apasat butonul de la dsc? am vazut ca mai apare un beculet pe langa cel dintre cadrane..
2. unde are antena de la radio montata un compact?
7825[/snapback]
Beculetu care se aprinde inseamna ca ai DSC 2 si poti sa dezactivezi si ABS!
Meserie
Lanterna este optional :)
Si eu am cautat-o cand am luat masina :blink:
Pentru geamurile care nu se ridica,cred ca trebuie o resetare ceva.
45317[/snapback]
Ale male merg ok.Cemai patzesc e ca sa am surpriza sa nu imi deschida centralu` de la cheie din an in pashti shi trebuie sa apas de 2 3 ori.
Daca ma intrebati de anumite lucruri din seria 3 E-46 poate le stiu.Asa ca cine vrea sa stie ceva sa scrie.Eu am sa incerc sa raspund dar numai cand am timp.
411[/snapback]
vreau sa aduc imbunatatiri la sistemul audio al masinii (330d 2002)navi 16:9 si anume daca pot adapta dvd si tuner tv ? si daca stie cineva cum se foloseste functia (TMC) la navi si in ce conditii ?scuze de deranj
1. Se dezactiveaza DSC-ul. Daca il apesi doar scurt, nu se dezactiveaza decat DTC-ul.
2. Habar n-am, probabil in luneta spate.
7826[/snapback]
sa va zic si eu ochestie,,,daca ti apasat dtc si se aprinde beculetul cu dtc la bord inseamna ca e activat tot timpul...si eu credeam ca se dezactiveaza...dar de fapt el ramane permanent activat si stfel in caz de derapaj timpul de reactie e mai bun decat daca s-ar activa automat...asa mi s-a spus de cei de la bmw cel putin la modelul e90...
aia cu volumul in functie de viteza merge si la mine .... se numeste speed vol 1...6 ... si se activeaza de butonul care selecteaza bas/treble/balans/fade ....samd
49149[/snapback]
si de ex daca speed vol la maxim cand masina merge cu vitezamai mare se opreste si muzica sau cum e cu treptele astea? la ce volum la ce viteza se micsoreaza volumul?:blink: poate nu m am exprimat prea clar dar poate intelegi ce vreau sa spun...
Eu nu am sesizat nici o diferenta desi am Speed Volume pe 6. Poate se activeaza de la 180 in sus, ca 316-le meu pe la 180 lesina.
49555[/snapback]
e cam ilogic sa creasca volumul odata cu viteza....ce se intampla daca tu ai 240 si muzica tot mai tare,aproape la maxim...pai la viteza mare ar trebui sa fie muzica la minim sa auzi zgomotele si vantul si alea alea...sa poti simti masina mai bine...e ciudata treaba cu speed volum -ul asta....
Valabil pentru E46 cu alarma OEM.
Daca se tine apasat pe butonul de deschidere a usilor cateva secunde,se vor deschide toate geamurile(dc. sunt electrice :blink: )
Ca sa inchidem geamurile,se apasa ...logic :)  pe butonul de inchidere timp de cateva secunde!
Acelasi lucru se intampla si cu trapa.
Rezultatul poate fi obtinut si intorcand cheia spre dreapta sau spre stanga cateva secunde.
361[/snapback]
hai sa zic eu una tare, se deschid intradevar dar nu se inchid,se inchid doar daca invart de cheie, de deschis se deschid din telecomada ????????????????
Asa e.Si la mine cand nu se mai invart rotile stergatoarele au o vit cam de 2 ori mai mica decat cea mai mica treapta. Banuiesc ca e facut din considerente economice...daca stau cu motoru pornit parcat 10min...de ce sa mearga alea pe cea mai mare viteza??
50698[/snapback]
dap, considerente economice, un consumator de energie (baterie) in minus la stationare...cand ai si farurile (cel putin teoretic) aprinse, clima pe dezabuire, etc...
197261[/snapback]
Eu cred ca explicatia tine de faptul ca stationand se strange mai putina apa...si ca sa nu zgarie parbrizul (sau sa nu dai de maneta de fiecare data cand opresti la semafor) trece automat pe cea mai mica treapta. :blink:
am descoperit ceva:
la e 46 cu xenon daca nu ai cheia in bord sau daca e pe prima pozitie( nu mai stiu sigur, mai degraba a 2 a varianta) si dai blituri ( faza lunga) se aprinde xenonul  :)  :)  :blink: si
224148[/snapback]
Este valabil si la "fara xenon" este "path way light"...parca asa se cheama. Adica parchezi in fata casei, scoti cheia din contact, dai flash, incui masina si dupa 30 de secunde sau un minut se inchide singura.
