Da sa moara motorul la turatii mari
ral
Ce valori trebuie sa arate sonda lambda la relantiu?La mine oscila intre 0.32 - 072 ceva de genu,iar cand a scos mufa incercuita in poza,s-a oprit motorul.
Am gasit valorile pe net ''Sensor values are read when the engine warmer than 70°C, and should be within 0.02 and 0.85 volts. Negative values indicate that the sensor needs to be replaced, and slow fluctuation indicate that the sensor is clogged with soot. Cars with catalytic converters that have been removed may push this code.''
