Schimbare DME
Salutare, am DME 0261203277 VIN: KA02432 , e36 318i M43 1993.
Intrebarea este daca exista alternative la DME sau numai codul respectiv ori nu merge. Din cate am inteles de la cineva, se poate pune un DME cu alt cod si se pune chip-ul de la cel vechi.
A mai facut careva "artificiul" acesta?
Din al meu pestii mai lipsesc, in rest are de toate, nici nu se mai vad diodele de pe spatele placii, chiar e un mister cum de a mers pana acum. Il spal cu benzina apoi cu spray pentru electronice, o sa il testez dar oricum, viata lunga nu are.
On E36 BMWs manufactured prior to July of 1994, there is a design problem with the car that has caused a lot of problems with the main DME computer. The water relief channels of the car are not beefy enough to withstand a significant influx of water onto the car, or the windshield. While perfectly adequate for anything that nature may throw at the car, the channels are woefully inadequate for a car wash. If too much water is used, or if the water channels are clogged with leaves or debris, the water will overflow and leak into the compartment where the DME is stored.
Se pare ca e greseala din fabricatie, scurgerile nu suporta un volum prea mare de apa.
Edited by Shocky
