Intrebare E93
SergiuJ
Va salut,
Stie cineva cum se pot programa butoanele de pe oglinda retrovizoare pentru deschiderea usii de la garaj?Multumesc
Daca mai ai manualul scrie acolo pas cu pas.Daca nu incearca sa il descarci si sigur ai sa reusesti.Uite ceva in engleza daca te ajuta.
96
Practical interior accessories
Integrated universal remote
control*
The concept
The integrated universal remote control
replaces up to three different hand-held
transmitters for various remote-controlled
equipment such as door openers and
house alarm systems. The integrated universal
remote control registers and stores
signals from the original hand-held transmitters.
The signal of an original hand-held transmitter
can be programmed on one of the
three memory buttons 1. Following that,
each of the devices can be actuated with
the appropriately programmed memory
button 1. The indicator lamp 2 flashes to
confirm transmission of the signal.
If the vehicle is sold, the memory of the buttons
1 should be cleared, refer to page 97.
To prevent possible damage or injury,
before programming or using the integrated
universal remote control, always
inspect the immediate area to make certain
that no people, animals or objects are
within the travel range of the device. Also,
comply with the safety precautions of the
original hand-held transmitter.<
Checking the compatibility
If you see this symbol on the packaging
or in the manual supplied with
the original hand-held transmitter, it
is safe to assume that it is compatible with
the integrated universal remote control.
If you have additional questions,
please consult your BMW center or
call 1-800-355-3515.
You can also visit these websites:
www.bmwusa.com or
www.homelink.com.
HomeLink is a registered trademark owned
by Johnson Controls, Inc.<
Programming
1 Memory buttons
2 Indicator lamp
Fixed-code hand-held transmitter
1. Turn the ignition key to position 2
2. When using for the first time:
Press both outer buttons 1 for approx.
20 seconds until the indicator lamp 2
flashes. The three memory buttons 1
are cleared
3. Hold the original hand-held transmitter
at a distance of approx. 2 in/5 cm to
8 in/20 cm to the memory buttons 1
The required distance between
the hand-held transmitter and the
memory buttons 1 depends on the relevant
system of the original hand-held
transmitter used.<
4. Simultaneously press the transmit button
on the original hand-held transmitter
and the desired memory button 1 on
Initially, the indicator lamp 2 flashes
slowly. Release both buttons as soon
as the indicator 2 lamp flashes rapidly. If
the indicator lamp 2 does not flash rapidly
after approx. 15 seconds, change
the distance
5. To program other original hand-held
transmitters, repeat steps 3 and 4.
The corresponding memory button 1 is now
programmed with the signal of the original
Edited by vartocp
