BMW E46 318i white alpine
-Sarpe-
BMW E46 318i
1999
Engine : I 4
Engine Code : 19 4E 1
Fuel : Petrol
Fuel System : MPI - Bosch BMS
Engine Alignment : Longitudinal
Drive : RWD
Displacement : 1895 cm3
Bore x Stroke : 85.0 x 83.5 mm
Type : 8 Valves
Aspiration : N/A
Compression Ratio : 9.7
Output : 118 cv (86 kW) @ 5500 rpm
Torque : 180 Nm (132 lb.ft) @ 3900 rpm
Gearbox : 5 speed Manual
Wheelbase : 272.0 cm
Length : 447.0 cm
Width : 174.0 cm
Height : 142.0 cm
Front Brakes : Vented Discs (286 mm)
Rear Brakes : Vented Discs (280 mm)
Kerb Weight : 1285 kg
Weight/Output Ratio : 10.8 kg/cv
Front Suspension : Independent. McPherson. coil springs. anti-roll bar
Rear Suspension : Multilink. Coil springs. anti-roll bar
Top Speed : 206 km/h (128 Mph)
0 to 100 km/h : 10.4 s
0 to 400m (1/4 mile) : - s
0 to 1000m : - s
Fuel Consumption* : 6.1L / -L / 11.0L / 7.9L (29 mpg)
Range : 797 km
Fuel Tank : 63 L
Trunk : 440 L
CO2 emissions : 190 g/Km
UPGRADE
1-faruri
2-bara Mtech 2
3-jante 17+cauciucuri profil V 225x45x17
4-embleme hamman
5-manson schimbator+ frana mana piele
6-schimbator M
7-ornament frana mana ACS
8-angel eyes
10-xenon far + proiectoare.
11-bloc lumini cu suport de proiectoare (masina nu a avut proiectoare)
12-stopuri model facelift
13-trimuri al look
14-inele bord titan look
15-spatiu depozitare cu jaluzea
16-ornament pedale al
17-foot rest ACS
18-pleoape hamman look
19-presuri mocheta
20-jante tabla+ cauciucuri noi iarna 205x55x16
PIESE SCHIMBATE
1-debitmetru
2-kit ambreiaj + semering cutie.
3-garnitura distributie+capac culbutori
4-valva disa
5-valva PCV+furtun
6-radiator
7-vas expansiune+furtun
8-buji
9-sonde lambda (ambele)
10-flansa cardan.
11-cotul din spatele motorului.
12-discuri (toate 4)
13-amortizoare(toate 4)
14-placute frana fata
15-bucse
16-bielete
17-capete de bara
18-filtru benzina
19-lichid frana
20-antigel
PLANURI DE VIITOR
1.faruri cu lupa
2-arcuri sport
3.2din (momentan are radio cass + magazie de 6 cd-uri)
asa arata in 2007 cand am cumparat-o
http://img535.imageshack.us/img535/1772/bmwstock.th.jpg
dupa 3 ani de investitii arata asa
http://img31.imageshack.us/img31/6011/24032010046ngnnnn.th.jpg
va urma....
  • Replies 73
mi sa parut mie ieri ca ma vazut bara de M ! Foarte bine arata .
si arata biiineeeeeee
Ar arata si mai bine daca si-ar schimba arcurile, acum arata ca un x5 :), recomand arcurile de coupe ( raport calitate/look/pret/ este cel mai bun)
5 degete fata si 4 degete spate probabil are acum :)
http://img695.imageshack.us/img695/4148/fgdm.jpg
Edited by edy1092
