problema pornire E46 2003
FAULT: Engine cranks but doesn't start. The fault code 209(decimal) or d1 (hex) (EWS/DME
alignment) is set in the DME.
CAUSE: EWS 3D module SW version O5. has software error.
SOLUTION: EWS module to be removed which is located on the left side of the vehicle, below
the instrument cluster, and replace with EWS 3D module SW version 06.(part no 61 35 4 101
593).Code the EWS module using DIS V16.0 or later.
Asta e valabil pentru Z3 din cate am citit pe un pdf dar ma gandesc ca poate fi aceeasi problema si la E46
