Cum aflu cati litri de combustibil mai am in rezer
wwwrza13
Nu ai la bord un ceas care sa-ti indice nivelul benzinei/motorinei ? Au si Daciile,ce naiba.
109046[/snapback]
Buey...asta e BMW...are ceva mai evoluat, ce dracu...nu un simplu ac indicator...are un adevarat crio-computer...care mai mult te incurca...cel mai bine e sa-ti montezi un volt-metru pe sonda din portbagaj, adica din rezervor...si sa-ti faci un sistem propriu de masurare a nivelului...desigur, e numai o idee...care trebuie f mult detaliata si experimentata :blink:
Pentru E46 ar fi test mode 6.
6.0 109330+ Fuel level averaged; Left half sensor input=10.9 liters; Right sensor input=33.0 liters
6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9 liters
6.2 0442+ Indicated value (44.2) and tank phase
Mooooooaaaaaaaaaa, cata matematica. Poate ceva serii Fourier te-ar ajuta mai mult. Si pana la urma ptr ce iti trebuie sa stii kestia aia?
edit: cate zecimale vrei sa ai, sau pe cati biti sa fie valoarea?
Edited by MaQ
Instructions to access the hidden OBC functions:
1. Hold Trip Reset while turning ignition key to on position
2. OBC should show "Test"
3. Use Trip Reset to select function 19.0 that unlocks all the features
3. Wait for display to show "Off"
4. Depress Trip Reset for 1/4 second and release it
5. With no delay press Trip Reset several times to select one of the following function s
BMW E46 On-Board Computer (OBC) Hidden Codes
nr example description
1 Car Engine and cluster data
1.0 46nnn Chassis nr/VIN serial number (last 5 digits)
1.1 4nnn K-number
1.2 690236 Cluster Part #
1.3 045210 Coding (04)/diagnosis (52)/bus index (10)
1.4 1200 Week (12)/year of manufacture (2000)
1.5 09_160 Hardware (09) and software # (16.0) of cluster
1.6 Not used
1.7 04__44 CAN-version (04) KI-revision index (44)
2 (test) Cluster System Test - Activates the gauge drivers,
indicators and LEDs to confirm function
3 SI Data
3.0 1098 Used fuel in liters since last SI (Service Inspection)
3.1 0231 Periodic inspection days; elapsed days (since last SI)
4 Momentary Consumption
4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km
4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour
5 Distance Gone Consumption
5.0 082 Average mileage; 082=8.2 liters/100km
5.1 0536 Calc. km to refuel (momentary distance to go)
6 Fuel Level sensor inputs in liters
7 Temperature and Speed
7.0 021+ Coolant/Engine temperature (2.1C)
7.1 130 Ambient/Outside temperature - chg met 5 pts. 125/130/135
7.2 + Engine speed / Current RPMs 1/min
7.3 + Vehicle speed / Current Speed in km/hour
8 Input value in HEX form
8.0 1d0+ System voltage ADC-Value Hex code
8.1 26C33C+ ADC Values HG left/HG right
8.2 0000 ADC Value brake degradation sensor (000=o.k.)
8.3 18C ADC Value outside temperature
9 Battery
9.0 140 Battery Voltage - 140 = UB 14.0v
9.1 242013+?
9.2 074_78+?
9.3 0011+?
10 Not used
11 Not used
12 Not used
13 GonG Gong Test
14 Not used
15 Status cluster I/O-ports (bit codes) 0=low; 1=high
1st-belt contact, seat belt fastened=0; 2) ignition lock contact, key inserted=0; 3) door contact, door open=0; 4) clock button pressed=0; 5) SI reset=0, for reset=0; 6) EGS transmission failure=0
Status Digital Outputs (bits) 0=inactive, 1=active
1) Gong output; 2) Brake warning lamp; 3) Low fuel warning lamp; 4) EGA lamp; 5) seat belt lamp; 6) manipulation dot
16 Not used
17 Not used
18 Not used
19 Lock Status; unlocks functions in range 3-18
19.0 L-On/L-Off Unlock: press button when "L-Off"
20 Not used
21 Software Reset; reset OBC settings
00 End of test
5. With no delay press Trip Reset several times to select one of the following functions
Am incercat si eu testele, dar nu merg decat pozitiile 1 - de la 1.1 la 1.7 si pozitia 2. Cand vreau sa merg mai departe la celelalte pozitii se intrerupe testul si revine la afisajul kilometrilor totali.
Trebuie sa selectez mai intai pozitia 19 si apoi o sa mearga?
Edited by alecsutzu4u
regula de 3 simpla !! :blink:
la 62/63L ...... y KM
x l ........ z km
Unde y = cam cati km faci tu cu 62 de litrii ...
unde x = catzi litrii are rezerva ( in momentul in care se aprinde becu ) - poti afla din posturile de mai sus :)
unde z = rezultatul; adica cat faci cu rezerva...
Si tot asa poti sa iti iei puncte de reper in functie de unde se afla martorul indicator al combustibilului....
demontezi reyervoru cu grija sa nu versi nimic, versi totul intr-o canistra dupa care umpli sticle de cate un litru si faci cate un semn cu pixul pe o hartie, dupa care numeri :blink:
109219[/snapback]
Eu zic ca cu seringa e mai precisa masuratoarea :)...dar atentie...sa nu aibe ac..ca se mai pierde si pe acolo cate o picatura...doua :)
bai nu mai faceti ma caterinca ca e misto faza, acum am plecat in masina sa vad daca merge ceva de acolo. Unde pui ca acum la 3:20 am facut si o tura cu masina cu testul pus la functia 7.3, sa vada ochiul meu exact cat am la ora frate. E marfa rau, indica si 2 km/h. sa inebunesc cand am vazut. Abia astept sa plec iar la drum lung, dar sa nu fac dracu accident stand cu ochii lipiti de contuarul de la kilometrii care acum indica viteza, care cred eu ca e la precizie de radar, de fapt de GPS. :blink:, oricum e marfa.
bai nu mai faceti ma caterinca ca e misto faza, acum am plecat in masina sa vad daca merge ceva de acolo. Unde pui ca acum la 3:20 am facut si o tura cu masina cu testul pus la functia 7.3, sa vada ochiul meu exact cat am la ora frate. E marfa rau, indica si 2 km/h. sa inebunesc cand am vazut. Abia astept sa plec iar la drum lung, dar sa nu fac dracu accident stand cu ochii lipiti de contuarul de la kilometrii care acum indica viteza, care cred eu ca e la precizie de radar, de fapt de GPS. :), oricum e marfa.
109384[/snapback]
Ai verificat si cati litrii de benzina mai ai? :blink:
109229[/snapback]
zice clar
si eu zic ca daca ai plinul la rezervor iti calculezi teoretic si aproximativcat o sa mearga masina cu litrii aia avand in vedere consumul minim mediu maxim (depinde pe unde ai drum)...dar asta nu o sa iti indice exact exact....daca iti ies 500 km s-ar putea sa fie doar 430 pana o sa ramai fara......cu exactitate nu cred ca poti afla.....decat dupa indicator....
