vand boxe , amplificatoare , subwoofere HELIX><BRAX<>MICRO-PRECISON
boxe amplificatoare subwoofere accesorii HELIX BRAX MICROPRECISION
SE MAI VAND SI ACCESORII HELIX BRAX + MATERIALE INSONORIZANTE + ACUMULATORI DEEP CYCLE
difuzoare :
COAXIALE HELIX
Helix DB 4.1 Dark Blue 10 cm putere: 20W RMS (40W max) - Pret: 131.00 ron
Helix DB 5.1 Dark Blue 13 cm putere: 30W RMS (60W max) - Pret: 143.00 ron
Helix DB 6.1 Dark Blue 16,5 cm putere: 35W RMS (70W max) - Pret: 167.00 ron
Helix DB 69.1 Dark Blue 6 x 9 inch putere: 50W RMS (100W max) - Pret: 239.00 ron
Helix E 104 Esprit 10 cm putere: 30W RMS (60W max) - Pret: 210.00 ron
Helix E 105 Esprit 13 cm putere: 40W RMS (80W max) - Pret: 251.00 ron
Helix E 106 Esprit 16.5 cm putere: 50W RMS (100W max) - Pret: 276.00 ron
Helix E 169 Esprit 6 x 9 inch putere: 50W RMS (100W max) - Pret: 342.00 ron
SISTEM 2 CAI HELIX
Helix DB 52.1 Dark Blue 13 cm putere: 40W RMS (80W max) - Pret: 312.00 ron
Helix DB 62.1 Dark Blue 16 cm putere: 50W RMS (100W max) -Pret: 348.00 ron
Helix E 135 Esprit 13 cm putere: 50W RMS (100W max) - Pret: 552.00 ron
Helix E 136 Esprit 16 cm putere: 60W RMS (120W max) - Pret: 588.00 ron
TWEETERE HELIX
Helix P 1 Precision Putere RMS - 25 Watts - Pret: 263.00 ron
Helix RS 801 Competition 25 mm high end tweeter - Pret: 596.00 ron
MID BASS HELIX
Helix P 205 Precision 13 cm Putere RMS / Putere Maxima - 50 / 70 Watts - Pret: 343.00 ron
Helix P 206 Precision 16.5 cm Putere RMS / Putere Maxima - 60 / 80 Watts - Pret: 364.00 ron
Helix RS 805 Competition 13 cm Putere RMS / Putere Maxima - 90 / 110 Watts - Pret: 677.00 ron
Helix RS 806 Competition 16.5 cm Putere RMS / Putere Maxima - 100 / 130 Watts - Pret: 727.00 ron
SISTEM 2 CAI MID-BASS + TWEETER + CROSOVER HELIX
Helix P 234 Precision diametru midbass 10cm tweeter 25mm putere: 40W (60W max) - Pret: 1,020.00 ron
Helix P 235 Precision diametru midbass 13 cm tweeter 25mm putere: 50W (70W max) - Pret: 1,044.00 ron
Helix P 236 Precision diametru midbass 16,5 cm tweeter 25mm putere: 60W (80W max) - Pret: 1,068.00 ron
DIFUZOR MEDIE HELIX
Helix RS 802 Competition Putere RMS / Putere Maxima - 35 / 50 Watts - Pret: 1,100.00 ron
AMPLIFICATOARE HELIX :
SERIA DARK BLUE
HELIX DB TWO DARK BLUE 2x80rms 4ohm, 1x200rms in punte - 672ron
HELIX DB FOUR DARK BLUE 4x60rms 4ohm, 2x180rms in punte – 864ron
HELIX DB FIVE DARK BLUE 4x60rms + 1x250rms 4ohm – 1271ron
SERIA ESPRIT
HELIX E10 ESPRIT 4ohm 350rms, 2ohm 550rms 1ohm 700rms – 1547ron
HELIX E40 ESPRIT 4x80rms 4ohm , 2x200rms in punte – 1787ron
SERIA PRECISION
HELIX P200 2x130rms 4ohm , 2x340rms in punte – 2387 ron
HELIX P400 4x110rms 4ohm , 2x350rms in punte – 2567 ron
SERIA COMPETITION
HELIX SPXL 1000 – 1x750rms 4ohm , 1x1200rms 2ohm , 1x1750rms 1ohm – 1847ron
HELIX A1 – 1x300rms 4ohm , 1x540rms 2ohm , 1x790rms 1ohm – 2627ron
HELIX A2 – 2x150rms 4ohm , 2x395rms in punte – 2747ron
HELIX A4 – 4x85rms 4ohm , 4x270rms in punte – 2987ron
HELIX A6 – 6x75rms 4ohm , 6x125rms 1ohm – 3467ron
SUBWOOFER HELIX
SERIA DARK BLUE
HELIX DB10 – 10inch 25cm putere 200rms 400max – 300RON
HELIX DB12 – 12inch 30cm putere 250rms 500max – 324RON
HELIX DB10 S cu tot cu incinta – 10inch 25cm putere 300rms 600max – 444RON
HELIX DB12 S cu tot cu incinta – 12inch 30cm putere 350rms 700max – 489RON
HELIX DB12BP cu incinta bandpass -12inch 30 cm putere 350rms 700max 719RON
SERIE ESPRIT
HELIX E250 – 10inch 25cm 2x4 ohm putere 300rms 450max – 479RON
HELIX E300 – 12inch 30cm 2x4 ohm putere 400rms 600max – 564RON
HELIX E250V cu tot cu incinta – 10inch 25cm 2x4 ohm putere 300rms 450max – 879RON
HELIX E300V cu tot cu incinta – 12inch 30cm 2x4 ohm putere 400rms 600max – 999RON
SERIA PRECISION
HELIX P8 PRECISION – 8 inch 20cm 4ohm putere 250rms 500max – 408RON
HELIX P10 PRECISION – 10inch 25cm 4ohm putere 300rms 600max – 528RON
HELIX P12 PRECISION – 12inch 30cm 4ohm putere 350rms 700max – 649RON
HELIX P8V cu tot cu incinta – 8inch 20cm 4ohm putere 250rms 500max –624RON
HELIX P10V cu tot cu incinta – 10 inch 25cm 4ohm putere 300rms 600max – 744RON
HELIX P12V cu tot cu incinta – 12inch 30cm 4ohm putere 350rms 700max – 969RON
SERIA COMPETITION HELIX SPXL 12 -12inch 30cm 2x2 ohm putere 1500rms 3000max – 1999RON
TOATE PRETURILE CONTIN TVA
PRODUSELE SUNT NOI SI SIGILATE
PENTRU COMENZI :
ID MESS : PILULA_20
TEL : COSMOTE 0765 568 446 SAU VODAFONE 0725 463 763
SE POT OFERI SI ANUMITE DISCOUNTURI!
Salut,ceva difuzoare de 10cm ai?Ma intereseaza numai dif de bass/medii fara con sau tweeter incorporat.
salut man...din pacate difuzoare de 10cm de midbass se gasesc mai greu...am o alta solutie daca vrei , pot sa iti explic ce ai putea sa faci pentru a gasi asa difuzoare de calitate si care sa sune foarte bine...intra pe id meu de messenger si vorbim mai multe...bafta multa...
ce dimensiuni au tweeterele
helix rs801 competition este tweeterul de varf din gama helix , i-ar astea sunt specificatiile pentru el
Frecventa - 820 Hz - 25 kHz
Senzitivitate - 93 dB 1W / 1m
Impedanta - 4 Ohms
Adancimea de montaj - 17 mm.
drilled 2,5 mm neodymium plate
coupling volume 18 ccm, filled with 1,1 g of damping wool
resonance frequency 820 Hz
delivery contents: 2 tweeters
delivered in high-grade wooden box
mai exista si helix precision p1
Specificatii tehnice:
Diametru - 25mm
Senzitivitate - 90 dB 1W / 1m
Impedanta - 4 Ohms
si mai exista si niste tweetere de la firma brax dar care sunt foarte scumpe...
pentru mai multe detalii ID DE MESS : pilula_20
Edited by pilula_20
Diametru - 25mm
Impedanta - 4 Ohms
tweeterele astea au vreun filtru , condensator pe circuit sau asta revine in sarcina mea
Diametru - 25mm
Impedanta - 4 Ohms
din pacate aceste tweetere vin fara filtre...un condensator se poate pune obtionat de catre tine sau de catre mine contra cost...
SE POT OFERI SI MONTAJE PROFESIONALE , IMBRACARE A TAPITERIE IN ALCANTARA ( DE ORICE CULOARE) SAU IN PIELE NATURALA LA FEL DE ORICE CULOARE , SE POT FACE INCINTE PENTRU BOXE DIN FIBRA , SE POT IMBRACA ELEMENTELE INTERIORULUI IN ALCANTARA SI PIELE NATURALA , SE POT FACE SUPORTI ELEGANTI DIN FIBRA PENTRU ELEMENTELE SISTEMULUI AUDIO, SE POT CONSTRUI MONTAJE DE CALITATE PENTRU AMPLIFICATORE , SUBWOOFERE
Ok si cat costa montatul condensatoarelor.
pei tweeterele costa 263 ron(helix p1 precision) + vreo 20-30ron condensatorii + montajul
mai este un set de tweetere momentan in stock...
vad ca tot lasi loc de intrebari , ca sa tii anuntul sus , urmatoarea intrebare era cat costa montajul dar renunt .
pei man eu ti-am scris cat costa tweeterele + condensatorii + montajul
pentru ca montajul pentru tweetere este gratuit pentru ca nu se depune prea mult efort...
Edited by pilula_20
cred ca tu nu ai montat la BMw de spui asa ceva :twoup: In cazul meu e vb de E90 in fata unde se da fata usa jos , se trag ramele geam afara , e risc sa rupi cateva clipsuri si sa iei bataie , si tot asa . MAi dai gratuit acum ? :)
fata de usa se desface la fel ca la orice masina din punctul meu de vedere.clipsurile alea daca stii sa tragi de usa nu se rup...daca nu ai incredere in mine te trimit la un garaj unde baietii aia o sa aiba grija de masina ta si or sa ti le monteze asa cum vrei tu...
upppp
  • 4 years later...
upppp!
Pe stock material insonorizant auto
STP ISilver Antirust Bulk Pack:
Cel mai popular produs STP iSilver primeste o imbunatatire,schimbandu-si numele in STP ISilver Antirust ,si este modernizat cu aditivi anti-ruginĂŁ pentru a se asigura cĂŁ șasiu nu rugineste
Acesta este un material impermeabil foarte flexibil, care aderĂŁ la suprafețe complexe ermetic, oferind cea mai mare amortizare a vibrațiilor pentru materialele de acest gen
Compoziție:
Un material multi-strat de amortizare a vibrațiilor cu suprafața exterioarĂŁ folie de aluminiu, strat de polimer pe bazĂŁ de cauciuc butilic și un strat auto-adeziv
Potrivit pentru : Uși, acoperiș, capac portbagaj, capac Bonnet, Firewall
- insonorizant cu foita metalica pentru reducerea vibratiilor
- anticoroziv
- eliminza zgomotele din exterior
- rezistent la apa si uleiuri
- dimensiune folie: 50 x 75 cm
- pachetul contine 10 folii, acopera 3,75 m2
Pret : 399.00 RON
Tel : 0724 710 809
Produs nou, sigilat , Garantie 12Luni
Nu accept schimburi !
Transport gratuit in Bucuresti
Sistem de difuzoare cu 2 cai + subwoofer
Match MS 83-BMW.1
Acest model de difuzoare este unul dedicat BMW fiind plug & play.
Se monteaza in locul difuzoarelor originale pe aceleasi prinderi!
-sistem de difuzoare pe 2 cai + subwoofer
-diametru midbass 10cm
-diametru tweeter 25mm
-diametru subwoofer 200mm
-tweetere cu calota din matase si magnet Neodynium
-crossovere incluse in pachet
-putere nominala - 100W RMS
-putere maxima - 200W
-raspuns in frecventa 30Hz-25kHz
-sensibilitate 90dB/1W/1m
-impedanta 4 ohmi
Modele Bmw compatibile :
Bmw Seria 1 E81, E82, E87, E88 (2004 - 2013)
Bmw Seria 3 E90, E91, E92, E93 (2005 - 2013)
Bmw Seria 5 E60, E61 (2003 - 2010)
Bmw X1 E84 2009 -
Bmw X3 E83 (2003 - 2010)
Bmw X5 E70 (2006 - 2013)
Bmw X6 E71 2008 -
Pret : 1300.00 RON
Tel : 0724 710 809
Transport gratuit in Bucuresti!
Match MS 42C-BMW.1
-putere nominala - 60W RMS
-putere maxima - 120W
-raspuns in frecventa 100Hz-25kHz
-impedanta 4 ohmi
Bmw X1 E84 2009 -
Bmw X6 E71 2008 -
Pret : 580.00 RON
Tel : 0724 710 809
Edited by pilula_20
  • 8 months later...
Up! pe stock sistem audio dedicate pentru urmatoarele tipuri de masini:
Produse de la firmele Match Audio & MB QUART ( made in germany )
1-seriesF205-door2011 -Front door & underseat F213-door2011 -Front door & underseat
2-seriesF22Coupe2011 -Front door & underseat F23Convertible2011 -Front door & underseat
3-seriesF30Sedan2012 -Front door & underseat F31Touring2012 -Front door & underseat F34Gran Turismo2013 -Front door & underseat F35Sedan Long Version2012 -Front door & underseat
4-seriesF32Coupe2014 -Front door & underseat F33Convertible2014 -Front door & underseat
6-seriesF12Convertible2011 -Front door & underseat F13Coupe2011 -Front door & underseat
X3F25SUV2010 -Front door & underseat
X4F26SUV2014 -Front door & underseat
1-seriesE813-door2004 - 2011Front door & underseat E82Coupe2004 - 2011Front door & underseat E875-door2004 - 2011Front door & underseat E88Convertible2004 - 2011Front door & underseat
3-seriesE90Sedan2005 - 2011Front door & underseat E91Touring2005 - 2011Front door & underseat E92Coupe2005 - 2011Front door & underseat E93Convertible2005 - 2011Front door & underseat
5-seriesE60Sedan2003 – 2010Front door* & underseat E61Touring2003 - 2010Front door* & underseat F10Sedan2011 -Front door & underseat F11Touring2011 -Front door & underseat
X1 E84SUV2009 - 2012Front door & underseat
BMW seria 3 (E46 - fara Compact)
Edited by pilula_20
