VAND URGENT PIESE DE PE E39 523i 1998
VAND SAU SCHIMB COMPONENTE DE VALOARE MULT MAI MARE,DE PE UN E39 523I 1998, CU CARDAN SI CUTIE MANUALA DE E39 525 TDS
-aeroterma cu motoras si radiator pt dublu climatronic 100e e39
-AMORTIZOARE FATA-SPATE 40 E buc
- AMORTIZOR CAPOTA 10E
- amortizoare capota portbagaj (haion) 10E
-arc fata 50 lei
-alternator 523 80E
-AFISAJ CLIMA 100 E
-APARATOARI FATA DE USA (cea intre fata de usa si usa )25 lei buc SET 4 BUC
-AX VOLAN 50 E
-axe came 2500 i 100e
-AIRBAG CORTINA ST /DR 50E BUC
-AIRBAG USI FATA /SPATE ST DR 50E BUC
-AIRBAG BORD 50E BUC
-ARIPA FATA E 39 25e
-ARIPA SPATE E 39 50E
-armatura bara spate E 39 40E
-baie ulei e39 2500 50e
-bara spate E 39 50e
- BIELA PISTON 30 E
-bloc 2500 diesel 6 cilindrii (an 1998) 250E
- bloc motor cu pistoane 523 i,400 E
- - borna baterie cu capsa pirotehnica 50 E
- bulb ulei(senzor presiune ulei) 20lei
-buton asc e39 30 lei
-buton avarie e39 30lei
-butoane geam electric 30 lei buc
-buton deschiderte porbagaj din interior 30 lei
-buton inchidere usi e39 30 lei
-buton lumini 100 lei
-buton proiectoare si ceata 70 lei
-buton GEAM ELECTRIC 70 LEI
- CALCULATOR AIRBAG 50E
-calculator inchidere centralizata 50e
-calculator LUMINI 50E E39
- calculator cutie viteze automata 525tds 1999 e39 50e
-CALCULATOR MOTOR 523i,e39 1998 100e
-cap bara st -dr .e39 50 lei
- CAPAC CHIULASA 523i 50e
- capac motor (cu sigla bmw) 523i 100 lei
- cardan 2500i manuala 70 E
-cardan 525 tds e39 1999 automat 70e
-capota portbagaj 50E
-carcasa sigurante 10E
-CENTURI FATA/ SPATE 1 mil buc
CONTACT USA (CEL CARE VINE PE STALP_50 LEI BUC )
-coltar geam dreapta spate 50 lei
-camanda DUBLU CLIMATRONIC 70E
-comanda 4 GEAMURI ELECTRICE +oglinzi (cea de pe usa sofer) 70e
- CONDUCTE SERVO , 20E
-COTIERA fata culoare NEAGRA 50E
-CUTIE DE VITEZE MANUALA 5TR 523i, 100E
-CUTIE DE VITEZE AUTOMATA 525tds e39 1999 IMPECABILA 300e
-CHIULASA 523i 200E
-debitmetru aer 523i 70e
-discuri spate ventilate originale bmw 100 LEI
-discuri fata ventilate originale bmw 100 le
-electromotor 523i 70E
-electroventilator clima 100E
-etrieri spate e39 30e buc st/dr
-etrieri fata e39 30e buc
- evaporator clima 50 E
-fulie A/C 2,5 500 lei (cea cate vine in centru la volanta din fata)
-FULIE VIBROCHEN 50 E
-FUSTA SCHIMBATOR VITEZE automat 20e
-FUZETA ST /DR fata-spate CU RULMENT 70 E
-flansa cardan 100 lei
- galerie admisie ,523i, 100E
GALERIE EVACUARE 523i, 50 E
-geamuri laterale 50e SPATE ST /DR
-GEAMURI FATA ST /DR 50E BUC
-grup cardanic(diferential) 523, 150 E
-HUSA MANER FRANA MANA 20E
- inchizatoare usi fata-spate stanga-dreapta 30E
-injectoare ,523, 150 lei
-instalatie electrica usi fata -spate, stanga-dreapta 50 lei
- intrerupator(comutator) stergatoare parbriz 50 lei
- intrerupator (comutator) lumini (faza lunga+semnalizare) 50 lei
-lampi interior 50 lei
-lampa de sub usa 30 lei buc
-luneta 50e cu dezaburire
-macarale electrice PT GEAMURI st /dr fata /spate 50e buc
-MANER FRANA MANA 20E
- modul lumini 50E
- motoras inchidere centralizata usi 40E
-MOTORAS STERGATOR PARBRIZ 50E
-motoras (pompa) lichid spalat parbriz 40 lei
-motoras clima 150 lei
-MANER DESCHIDERE USA EXTERIOR 20 E BUC FATA SPATE STANGA DREAPTA
-manere interior deschidere usa 40 lei buc cel nikelat
-motoras inchidere centralizata usa + usita rezervor 50 LEI BUC
-motoras oglinda 100 lei
-MOCHETA PODEA spate E39 50E NEAGRA
-mocheta porbagaj coltarele 50 lei
- oglinda retrovizoare interioara 30E
-opritor usa exterior 50 lei
-pedala acceleratie 50 lei
- pison 2300 i, 50 E
-PLAFON 100E
-plastic intre filtre polen 50ron
- POMPA FRANA 520,525,530 d, 525 tds, 520,523,528,535,540 i 50E
- planetare 523,525,528,535,540 i 100E
- plutitor rezervor stanga-dreapta 30E
- radiator clima 70E
-radiator servo(teava aluminiu) 25 E
- radiator(racitor) ulei 50E
- REGLAJ VOLAN MANUAL 50E
- rezervor benzina 520,523,528,525,535,540 i 100 E
- rezistenta turatie aeroterma (piesa cu tepi) 100 lei
- intinzator hidraulic E39, E34, E36, E46,E 60, E 61 X5, X3 motoare benzina 30 E
- scaune+banchete textil 100E
-scut motor 30E
-scut motor plastic (cel rombic) 30E
-soclu bricheta 30 lei
-senzor centura 1 mil
-senzor impulsuri axe cu came 520,523,528,i E 39, 320,323,328 i E36 100lei
- SENZOR NIVEL ULEI 520,525,530 d 30 E
- senzor nivel ulei 520,523,528 i 30E
- senzor nivel motorina stanga-dreapta 20 E
-senzor prezenta scaun pasager dr 1 mil
-senzor rampa presiune 50 E
- senyor regulator presiune injectie 520.523.528 i,320,323,325i 50 lei
-senzor temperatura evaporator clima 30 lei
- senzor unghi virare (cel de pe ax volan) 50 E
- servo frana 100 E
- sonde lambda 520,523,528 i, 320,323,328 i 100lei buc
-spira airbag 50 lei
-stopuri HELLA SEMNAL GALBEN 150 ron
- suport ax volan 50E
- SUPORTI BARA FATA-SPATE 20 E buc
- suport cutie viteze automata 15 E
-SUPORT MOTOR 100E
- suport filtru ulei 520,523,528 i 50 E
-TAPITERIE PLAFON 100 E
-tub injectie 520,523,528 i 50E
- TUB TIJA NIVEL ULEI 10 E
- timonerie cutie viteze automata 520,523,528 i 40E
-torpedou 30e
- toba esapament originala finala bmw 50E
-USI e39 FATA-SPATE pt berlina si combi 200e buc
-usita rezervor e39 50 lei
-usita culisabila CD / CASS 30e
- valva regulatoare presiune /separator ulei 520,523,528 i, 320,323,328 i E 36 50 lei
- valva reyervor benzina 520,523,528,535 i, 318,320,323,328 i 15 E
-vas exp pompa frana 10E
- vibroken 520,523,528i, 320,323,328 i 100 E
- volanta cutie automata 520,523,528, E39, E36, E46,E6 ,E61 X3, 50E
- aparatoare noroi originale fata 100 RON
__________________
Edited by lazarfl76
sal,ma intereseaza daca ai pt 523i din 98' radiatorul de apa si elicea de la pompa de apa fara vasco-cuplaj deci doar elicea aceea de plastic, precizez ca masina mea este dublu climatronic si cu cutie automata am inteles ca e o diferenta la radiatorul de apa si un pret daca le ai. O zi buna
NU ESTE
IMI PARE RAU
Nu sunt
imi pare rau
Topicul va fi inchis 10 zile pentru nerespectarea regulilor din sectiunea de MP. Este obligatie fiecarui user care posteaza in sectiunea de MP sa citeasca si sa respecte regulile specifice sectiunii.
Este permis un singur UP la 7 zile, indiferent de motiv.
7. Initiatorul topicului poate da un singur UP la 7 zile de la ultima sa postare. Nu se admit UP-uri date mai repede de 7 zile de la ultima postare sau UP-uri date de catre alta persoana decat initiatorul topicului. Exceptia UP-ul la 7 zile va fi permis doar atunci cand initiatorul doreste sa scada 10% din pret. Daca se da UP inainte de cele 7 zile topicul va fi inchis 10 zile. Sunt considerate UP-uri si actualizarile de stocuri, noi produse, sau postarea de poze in intervalul celor 7 zile. Din acest motiv, topicurile trebuie sa contina cat mai multe informatii inca de la deschiderea lor.
Redeschiderea topicurilor inchise la MP.
Topicurile vor fi redeschise DOAR la solicitarea initiatorului, in urma unui report trimis DUPA expirarea sanctiunii. Obligatoriu in report se va trimite un link catre topic, altfel solicitarea nu va fi luata in considerare. Este interesul si obligatia vanzatorului sa solicite deblocarea anuntului dupa expirarea sanctiunii.
ma intereseaza
si volanta pt ea daca am nevoie ... pt k e mai complicat , vreau sa pun cutia pe un e39 525d din 2001 si trebuie sa ma documentez bine daca se potriveste in locul cutiei manuale .
ma intereseaza
te intereseaza sistemul de prindere al cutiei de motor!
-eu tocmai am facut operatiunea inversa a ceea ce vrei tu sa faci si a mers!:twoup:
-deci daca te hotarasti sa faci chestia asta,te pot ajuta cu tot ce iti trebuie la preturi super omenoase!
cutie viteze automata+volanta de cutie automata-300 euro
Edited by lazarfl76
ma intereseaza
deci tot ce am nevoie pt schimb in 300 euro ? oare merge pe 525d ?
ma intereseaza
tu ai nevoie de mai multe treburi pentru a face conversia la masina ta.
eu iti ofer cutia de viteze cu tot cu volanta la 300 euro,usor negociabil!
cred ca se potriveste sistemul de prindere al cutiei automate de motorul tau!ce VIN are masina ta?
Edited by lazarfl76
salut. un MID central ala de sub casetofon, modelul cu ecran lung, cu buton de BC si buton de telefon daca ai, si niste duze pt. spalat farurile.
duzele au fost vandute odata cu bara de fata,iar cu mid-ul era cu ecran mic si a fost vandut cu tot cu casetofon.
imi pare rau!
cu respect,florin!
