Probleme compresor clima BMW E90
Salut!
Compresorul de clima refuza sa porneasca. Mentionez ca am pe masina un compresor Calsonic PV6 cu cilindree variablia (nu are ambreiaj electromagnetic pe Fulie). Am incarcat instalatia corespunzator cu cantitatea necesara de "freon" dupa ce in prealabil instalatia a fost verificata si efectuata operatia de vidare. Dupa toate astea am constatat cu stupoare ca nu porneste compresorul.
Mai are cineva acest model de compresor pe masina? Cum functioneaza? Care ar putea fi cauza?
Ms mult si astept raspunsurile voastre?
Au fost puse masinile la tester ? Oare nu ar trebui sa indice cauza ?! Cu siguranta este ceva electric: poate fi si o siguranta si un contact si ventilatorul mare de pe radiator (astea le stiu eu) si probabil si altele.
Mircyus cunosti vreun tester in Targu Mures ?
I just checked for this bulletin about the e90 AC (I'm a BMW tech) and there is NO bulletin which leads to replacement of the entire A/C system. the two relevant bulletins refer to the following:
A/C doesn't blow cold: Expansion valve faulty, must be replaced, possibly along with dryer (please don't ask me to explain all the parts, go to www.howstuffworks.com and check out Air Conditioning)
A/C stops blowing cold on long drives (1 hour plus) caused by bad temp sensor in the evaporator, causing evap to ice over, stopping cold air flow. Replace sensor and adjust some wiring.
NO bulletin about replacing the whole a/c. there may have been something specifically wrong with yours, and they were led to replace the whole thing, but not by bulletin.
Pe langa asta cred ca ar trebui sa duci masina la reprezentanta . Cel mult platesti un tester si poate afli cauza
Citeste si aici poate gasesti printre probleme si asta
http://www.e90post.com/forums/showthread.php?t=1462
Si studiaza E90 post bine am vazut ca sunt cateva probleme cu Ac
Edited by Myx
Sa inteleg ca tester-ul nu da nici un verdict ?! :twoup:
Am fost cu masina sambata la baietii de la TCM si cum ti-am zis testerul a gasit cateva erori legate de lumini si inca ceva, dar nici una nu avea legatura cu clima.
Azi am fost langa job cu masina. E un service la Podul Constanta. Am pus masina pe tester dupa ce au reincarcat cu freon si cu ulei compresorul si nici o eroare. Clima tot nimic. Compresorul nu porneste.
Cat am fost acolo azi baietii au verificat sigurantele au verificat daca ajunge curent la compresor si totul e in regula.
Singura varianta care i-mi trece prin cap e sa nu se fi ars compresorul sau cu toate ca pe fire pleaca 12 v la sursa sa nu mai ajunga 12 v reali.
Cum am zis am verificat pe doua testere. Nici unul nu a gasit nici o eroare sau defectiune. O sa mai merg miercuri o data cu masina in service.
Nu ma prea pricep la tehnica asa ca nu ma blamati daca am expus ceva eronat
Sincer nu stiu pe nimeni in Tg Mures sau macar prin apropiere priceput pe partea de diagnoza la BMW. Daca stie cineva sa imi dea un numar de telefon si in ce localiatea se afla specialistul. Reprezentatnta din Mures e praf nici nu am gandesc sa trec pe acolo. Eventual o sa incerc in Cluj, doar ca, din pacate nici acolo din cate am inteles nu sunt prea priceputi.
Tensiune ajunge in mod cert la compresor pt ca se aude cum tacane cand cuplez clima, si in plus l-am legat si pe direct. In momentul in care cuplez clima creste si turatia la motor cea ce este iarasi normal. Posibil sa fie dus compresorul cea ce nu prea e normal la o masina cu 76.000 de km.
Multumesc oricum pentru informatii si astept in continuare cu interes parerile voastre.
Edited by mircyus
GoldFit in Sangeorgiu de Mures. Sun ok baietii
tel 0365-407.928
  • 9 months later...
am si eu o problema asemanatoare nu porneste clima , nu baga rece deloc , si se aude un zgomot ciudat in zona compresorului , eu unu ma gandesc ca este fulia rupta .
exista mai multe modele de compresoare pe bmw 320D e90 ?
  • 11 months later...
Am si eu o problema cu fulia de la compresor ! Rulmentul face foarte urat , aveti idee unde pot gasi sa schimb doar fulia , am gasit ceva pe net in germania dar este cu 4 canale iar la mine este nevoie de o fulie cu 6 canale .
BMW E90 320 D 163 HP
Multumesc mult !
Poate vrei fulia de la motor ?! la compresor ar trebui sa aibe 4 caneluri
l.e. acu am vazut ca este e90 ,nu e46 :) ..pai da , 6 are..cica la servo are curea cu 4
de ce nu iei compresor cu totul !?
Edited by gelu_bmw
Pt ca e mult prea scump , am gasit fulie pt el dar e pe 4 canale , am gasit si fulie pe 6 canale in germania dar zice ca e pt seria 5 6 7 , eu l-am dat jos , problema este la rulmentul care este fixat in fulie ... in caz ca nu o sa gasesc ... nu ramane decat sa schimb compresorul . :(
Pt ca e scump , in ultima instanta o sa il iau daca nu gasesc fulia , am gasit pe net fulie separat de compresor de e90 dar este cu 4 canale iar eu am nevoie de una cu 6 canale , cele cu 6 canale spun acolo ca sunt pt seria 5.6.7 .. deci , nu stiu ce sa fac , poate sa mai lovit cineva de problema asta si ma poate ajuta !
Daca nu este vreo problema de la compresor, fulie sau alte piese puteti sa verificati senzorul de temperatura exterioara. La e46 este in bara din fata. Aceeasi problema am avut si eu toata vara trecuta. Compresor ok, freon ok toata instalatia ok si eu nu aveam racoare. Am umblat prin zeci de service-uri si degeaba. Pusa pe tester cand apasam butonul cu "fulgulet" se aprindea dar nu trimitea comanda la compresor. Cand sa vezi senzorul de temperatura exterioara stricat si arata -40 de grade iar computerul ei nu te lasa sa bagi rece pe -40. Schimbat senzorul si compresorul a pornit de prima. Incercati si asa poate rezolva problema.
  • 3 years later...
  • 10 months later...
Salutare baieti! Eu am alta problema, mie de ieri nu imi mai baga deloc, nici cald, nici rece, nici ventilatie, NIMIC! Cand apas pe acolo pe butoane se aude ceva ca si cum ar da sa porneasca, dar nu porneste. Stie cineva ce poate avea? Mai sunt si alte sigurante in afara de cele din torpedou?
Este vorba de un E90. Multumesc!
Am aceeasi problema ca si tine, in seara asta am observat. Acum 2 zile mergea incalzirea, azi se aude ca da sa porneasca, dar nu porneste. Daca dau pe MAX, se duce la 16 grade dar nu baga aer deloc. Sa fie de la sigurante sau altdeva?
Multumesc!
  • 1 year later...
