[Dezmembrez] e39 an 2000
  • Replies 204
AU MAI RAMAS:
0749574887
AMORTIZOR DREAPTA SPATE CU TOT CU ARC SI FLANSA 50 E
-arc fata 50 lei
-AIRBAG CORTINA ST /DR 200 LEI BUC
-AIRBAG USI FATA /SPATE ST DR 200 LEI BUC
-armatura bara spate 200 LEI
-BASCULA ST /DR fata 150 LEI BUC
-bara spate E 39 200 LEI
-BARA STABILIZATOARE FATA E 39 150 LEI
-buton inchidere usi e39 50 lei
-buton lumini 100 lei
-buton proiectoare si ceata 100 lei
-DIFUZOARE BOXE NOKIA E39 SET 100 LEI BUC
-calculator LUMINI 250 LEI
-calculator PDC (SENZORI PARCARE ) 250 LEI
CALCULATOR MOTOR 3000 d, 184 C.P. 300 LEI
- CAPAC MOTOR 530 D (cu sigla BMW) 100 LEI
- CAPAC MOTOR FILTRU AER 50 LEI
-capota portbagaj 300 LEI
-CENTURI FATA/ SPATE 50 LEI buc
-coaja bord NEAGRA 400 LEI
-debitmetru aer 100 LEI
-discuri spate ventilate originale bmw 100 LEI
-discuri fata ventilate originale bmw 100 lei
-ELECTROMOTOR 300 LEI
-etrieri spate e39 100 LEI buc st/dr
-etrieri fata e39 100 LEI buc
FETE DE USI interior 100 LEI BUC
-FUZETA ST /DR fata-spate CU RULMENT 300 LEI
-geamuri laterale 150 LEI SPATE ST /DR
-GEAMURI FATA ST /DR 150 LEI BUC
-grup CARDANIC 800 LEI
-INJECTOARE 250 LEI BUC
-macarale electrice PT GEAMURI st /dr fata /spate 200 LEI buc
- motoras inchidere centralizata usi 100 LEIE
-MOTORAS STERGATOR PARBRIZ 300 LEI
-motoras (pompa) lichid spalat parbriz 50 lei
- oglinda retrovizoare interioara 150 LEI
- plastic filtru aer 150 ron
-pompa injectie diesel (INALTA PRESIUNE) 800 LEI
-POMPA VACUM 200 LEI
-PLANETARA 250 LEI BUC
-rezervor motorina 500LEI
scaune banchete spate + ski sac 300 lei
-senzor ABS spate 100 LEI
-senzor centura 100 LEI
-stopuri SEMNAL ALB 250 ron
-TRAPEZ SPATE 200LEI
- toba esapament originala bmw 250 LEI
- valva EGR 100 LEI
oglinda stanga fata noua in cutie 300 ron
ROLA ACCESORII NOU 150 LEI
PRETURI FOARTE MICI IMI OCUPA SPATIU DEGEABA ACESTE PIESE
0749574887
salut , vezi poate reusesti sa gasesti mufa aia...poti sa o aduci si pe cea movalie de la modulul de lumini? merci man ..fac cinste.
mufa nu o pot aduce pentru ca nu o am la galati.instalatia electrica este intr-o localitate din apropierea galatiului.iti pot aduce modulul care-l am eu si ti-l las sa vezi daca se potriveste.si ne intelegem dupa aia.salut
este acel rulment dar nu stiu in ce stare se mai poate afla.daca il doresti asa costa 50 lei.
sal , ai citit si mai jos ? am nevoie si de termostat , ai unul bun ? sa imi dai si codul de pe el sa stiu daca merge si un pret . ms
termostatul il am.dar la fel nu stiu cat de bun mai poate fi.iar termostatul iti trebuie cu tot cu capul de plastic in care vine iar eu il am separat.termostatul si cu acel rulment sunt piese de cumparat de noi nu prea merg sa pui sh.tu stii cel mai bine acum, nici nu vreau sa-ti trimit piese care stiu eu ca e posibil sa nu fie intr-o stare buna.salut.
