bmw 850 ci
wefy
The 850i was available with either a 4-speed automatic or a 6-speed manual gearbox.
Da ma rog nu 95 e 94 oricum scrie ca si bmw sau contrazis despre momentul aparitii
It is quite tricky to distinguish between the 850i and the 850Ci. You can read from the production table that production of these two models was overlapping for eight months. And the upgrade to the advanced M73 engine did not coincide with the change in the type designation. In addition even material from BMW contradicts itself. You can read in the owner's handbook of a '93 850CSi that the 850Ci has a 300hp engine (the M70). According to BMW production figures the 850Ci does only exist since the M73 engine with 326hp was built into it (1994).
The 850Ci with M70 engine was available with a 4-speed automatic or a 6-speed manual transmission, the 850Ci with M73 power plant only with the 5-speed automatic gearbox. So there are no 5.4l 850s that are manual.
  • Replies 90
Respect pt. munca si sunt sigur ca la costat destul de mult manopera dar ceva parca nu da,nu se potriveste cu masina,am vazut e60-uri cu interiorul culoarea asta dar acolo este altceva are si imitatie de mahon,aici parca nu se potriveste,mai bine alegea daca tot sa hotarat sa imbrace interiorul culoarea neagra,iar daca nu este inmatriculata de ce sa mai apucat de ea?in fine este treaba lui,banii lui,dar ziceam asa....
Bine ca ziceai tu asa...nu ti se pare prea inalta? parca nici scaunele alea nu sunt chiar asa confortabile nu ?
on: Frumoasa masina .. ma indoiesc de cei 470 de cai ... dar totul este posibil..
Multumesc pt. aprecierile referitoarela manopera. Probabil in poze pare piele ecologica, insa e piele naturala de cea mai buna calitate. Uitati-va in X5-- ul pachet M modelul nou si veti vedea aceeasi textura. Ma ocup cu tapiterii de vreo 7 ani si stiu ceva despre asta. Referitor la nuanta aleasa bineinteles ca parerile sunt impartite si gusturile de asemena.
Inca ceva, interiorul arata foarte bine si inainte, insa s-a dorit o transformare. Aproape toate au interiorul negru din fabrica si atunci nu mai exista nimic contrastant cu exteriorul.
Edited by wefy
Oare la E36 se potriveste cu scaunele sport? :twoup:
Sigur ca da , dar tot "incomode " vor fii pentru bogdyy !!!
A aparut din "concediu? si a inceput iar cu sorcova pe forum !!
On topic: Arta bine masina dar mie nu-mi place deloc interiorul. Eu as fi preferat sa fie cat mai original, fara piese imbracate care de fabrica n-au fost si o culoare mai inchisa.
Edited by sax1987
Nu mi se pare piele naturala, cel putin pe panourile de usi se vede cel mai bine.
E posibil sa fii vazut tot o piele sintetica si in X5, cel putin la X3-uri e leatherette, care este exact cum spui tu, aceasi textura, dar nu este piele.
http://www.bmwblog.com/2009/02/04/leather-...uld-you-choose/
Edited by WLF
Mai conteaza ce piele este ? Hai sa facem un topic nou : "ce tip de piele are 850 I sau CI". (de fapt deja putem 2)
E deosebita masina, imi place. Un singur amanunt nu imi place si anume cusatura de pe piele ca este de culoare inchisa, stiu ca s-a incercat un contrast.
Catre WLF in special. Da-mi voie sa-ti spun ca este piele suta la suta. Eu am tapitat interiorul deci stiu ce vorbesc. Daca tu vrei sa te convingi iti trimit o bucata din acea nuanta sa o ti in mana. Dar nu cred ca esti un copil totusi indaratnic. Nimeni nu e nebun sa faca tot interiorul la asa masina in piele ecologica. Edited by wefy
Eu nu sunt sceptic. E vorba de standardul fiecaruia. Pur si simplu o piele care seamana ca textura cu o piele ecologica, conform standardelor mele personale, nu este de calitate. Ca tu spui ca e de calitate, inseamna ca probabil ai alte standarde, ori nu stii ce e pielea de calitate, din ciclul merge si asta. E ca si cum mi-as lua o geaca de piele si m-ar interesa doar modelul, fara sa ma uit la calitatea pielii.
WLF Sa stii ca si pielea ecologica e de foarte multe grosimi, texturi si calitati. De asemenea pielea naturala. Texturile difera de la producator la producator si in functie de grosime. La unii producatori, spre exemplu, pielea nappa nu are nici o textura iar la altii are, dar de dimensiuni mici. Calitatea nu e data doar de textura ci de rezistenta la uzura (indoire, zgariere etc.).. Si mai e o chestiune in a alege materialul folosit. Placerea celui ce o va folosi.
Pe mine personal ma intereseaza parerile tuturor deoarece pot fi de folos. Insa cele neargumentate si cu tenta rautacioasa si de dispret fata de o persoana totusi necunoscuta mi se par mult deplasate. Multumesc pt. intelegere
io cred ca mai mult faci reclama la ceea ce faci tu decat sa prezinti masina.
te-am rugat de niste poze de sub capota si explicatii cu ceea ce scrie in titlu despre puterea motorului... asltfel nu-si mai are rostul acei "470 hp"
inca nu am pozele cu motorul. le voi avea si le voi posta impreuna cu explicatiile despre motor. iar despre reclama nu poate fi vorba deoarece nu a pornit topicul cu asa ceva. doar ca unii se gasesc sa faca unele comentarii nefondate la care e normal sa raspund. puteam sa pun reclama in alta categorie. lucru pe care nu l-am facut
Iata explicatiile cailor in plus:
-schimbat si modificat
-biele
- pistoane cu cap de titan
-segmenti modificati pt. turbo
-chiulasa cu supape cu diametru marit si arcuri pe supape schimbate
-axe cu came cu unghi de atac modificat
-injectoare de 750 ccc/ buc
-soft modificat in calculatorul de injectie si in elm
-admisie argintata pe interior
-evacuare Magna Flow (fata-spate)cu diametrul maxim posibil pt. 12 cilindrii
-2 pompe de ulei in cascada ( original e una)
-regulatoare presiune reglabile
-bujii Iridium (contacte de platina)
Initial motorul a fost construit si modificat pentru 2 turbine insa din cauza lipsei de spatiu in compartimentul motor ar fi trebuit montate in bara spate in locul tobelor finale. Modificarile ce urmau a fi facute pentru evacuare, racire, intercooler etc nu mai aveau rost, masina avand deja o putere mare.S-a facut un test pe Dyno in Ungaria doar a motorului cu cele 2 turbine direct pe evacuare si puterea rezultata nu era una si necesara. Las la latitudinea celor ce stiu sa aproximeze cam ce putere dezvolta un v12 biturbo modificat.
Poze inca nu pot posta din cauza unor probleme de ordin tehnic. Probleme cu calculatorul in care sunt salvate. Se spera recuperarea lor deoarece sunt poze de pe parcursul intregii lucrari de reconstructie a motorului.
Eu nu am deschis acest topic nici ca sa-mi fac mie reclama cum mi s-a spus nici cu alt scop. Sunt un fan BMW, am avut BMW e30, e36 am e39 si voi mai avea. Si pentru ca E31 e o masina speciala iar in acesta am fost implicat direct, m-am gandit sa impart si altor fani BMW virusul 850. Doar atat
-biele
AdicĂŁ e supraalimentatĂŁ?
Vezi cĂŁ evacuarea nu e rapidĂŁ dacĂŁ are diametru maxim posibil, bujiile NGK Iridium nu dau putere ĂŽn plus.
