Bartolomeus
Orice facelift e46 316i/318i, chiar si din 2001 (primele modele de fl) iese euro4.
Nu e adevarat.Al meu 325i e46 este facelift si este fabricat in 10/2001.Este euro 3 si am platit 2800 euro taxa de inmatriculare in 2010 cand am luat-o.
Dupa cum arata asa pare dar singura metoda prin care poti prezice intr-o oarecare masura km unei masini sunt intrarile in service pe care le are. Verificate la Bavaria. Destul de scump retrofit-ul pt CIC, sunt sanse mari sa fie din fabrica dar asta aflii usor dupa un vin decoder
Ce-o zice google?
Dynamic cruise control is an electronic cruise control system with an extra braking function. This also includes the Curve Speed Limiter that reduces the speed in curves for comfortable lateral acceleration. At the end of the curve the car accelerates and resumes the original speed. The driver can change this in increments of 1 or 10 km/h. Acceleration and deceleration in two dynamic settings can be controlled by manipulating the lever on the steering column or the paddle on the steering wheel (Comfort Dynamic system).
Edited by Laur R.
