Bartolomeus
Rugaminte catre voi caci aveti ochiul mult mai format decat mine.
E ceva serios in neregula la masina asta din ce vedeti in poze ?
Am gasit www.autovit.ro/bmw-330-C36594031.html si pare interesanta tinand cont de pret si de faptul ca este inmatriculata deja.
Sunt constient ca masina o sa manance 2-3000 euro in primul an ca sa ajunga dpdv tehnic in top shape ( ca dealtfel orice SH la banii astia ).
Daca e sa caut aceeasi configuratie adica XI 2.5-3000cmc in Alemania tinand cont de drum, benzina, numere, asigurare, imatriculare sar cu mult de acesti 3000 euro care sa presupunem ca ii toaca masina ca sa fie in mintile ei in primul an.
Nu ma intereseaza nr de km caci oricum nu ii pot crede indiferent cati ar fi... poate doar daca declara 380000 atunci da, credeam.
Am vb cu omul, am obtinut seria de caroserie respectiv wbaaw51040ju11195
La o cautare pe net obtinem urmatoarele date :
Data for vehicle identification number: WBAAW51040JU11195
Model description: 330I
Market: Europa
Type: AW51
E-Code: E46 (3)
Chassis: touring
Steering: links
Doors: 5
Engine: M54 - 3,00l (170kW)
Drive: Heckantrieb
Transmission: automatisch
Body Color: Orientblau Metallic (317)
Upholstery: Standardleder/schwarz (N6SW)
Production date: 18.01.2001
Assembled in: Regensburg
Code Standard Equipment
S375A Convertible top, electromech., black
S411A Window lifts,electric,front/rear
S473A Armrest front
S520A Fog lights
S548A Kilometer-calibrated speedometer
S550A On-board computer
S832A Battery in luggage compartment
Code Optional Equipment
S169A EU3 exhaust emissions standard
S203A 4-wheel drive
S205A Automatic transmission
S210A Dynamic stability control
S249A Multifunction f steering wheel
S255A Sports leather steering wheel
S261A Side airbags for rear passengers
S265A Tyre pressure control (TPC)
S302A Alarm system
S313A Fold-in outside mirror
S358A Climate comfort windscreen
S386A Roof railing
S431A Interior mirror with automatic-dip
S434A Interior trim finishers
S441A Smoker package
S459A Seat adjuster, electric, with memory
S488A Lumbar support, driver and passenger
S502A Headlight cleaning system
S508A Park Distance Control (PDC)
S521A Rain sensor
S522A Xenon Light
S534A Automatic air conditioning
S609A Navigation system Professional
S672A CD changer for 6 CDs
S674A Hi-Fi System Harman Kardon
S785A White direction indicator lights
S855A Language version Italian
S863A Retailer Directory Europe
S877A Delete cross-pattern operation
S884A On-board literature, Italian
S915A Delete clear coat
S928A Tire control
Eu mi-am facut socotelile asa : 2200 euro masina, 3000 euro investit in ea sa fie mecnaic tipla poate inca 1000 in estetica, total 6000 euro pt o masina buna, cu motor decent, care sa poata merge si iarna gratie 4x4.Intentionez sa o tin mai mult de 5 ani.
Gresesc ?
Multumiri multe pentru rabdarea pe care o aveti cu mine si pentru raspunsurile pertinente !
Edited by Cumnatu
2200ron impozit si probabil 1100ron RCA, e suportabil, nu e aia problema.
Sub 325 nu scad si acolo impozitul este 900 si rca tot cam pe acolo.
Dar unde sunt 150 lei / luna pt taxe sunt si 300 lei / luna, zic.
( singurul motor interesant mai e cel de la volvo 2.3t5 dar nu ma omor dupa masina in sine motiv pt care sunt axat pe 325 sau 330 xi )
In rest ?
Edited by Cumnatu
Mi-e greu sa cred ca are taxa platita. Si pare un cazan numai dupa husa aia de pe volan. Pare sa aiba si anvelope de dimensiuni diferite fata-spate. De restul nu ma pot pronunta.
Daca ai timpul si rabdarea necesara (ca de bani inteleg ca nu se pune problema), da, poti scoate ceva frumos din ea. Baza sa fie buna.
Cumnatu , verifica BINE masina din toate punctele de vedere la un mecanic in care ai incredere sau un garaj, dar insista cu verificarea taxei (sa nu iti serveasca o hartie falsa de plata a taxei )
MyKe treaba cu anvelopele de dimensiuni diferite eu nu prea vad care e problema, si eu am diferite , fata 255/50 si spate 285/45 :popcorn:
E OK atunci cand pastrezi diametrul initial sau te incadrezi intr-o anumita marja. Si eu am in carte 235/45 si 255/40.
Dar masina pusa de Cumnatu pare sa aiba ceva de genul 225/45 pe fata si 235/45 pe spate (se vad mai "umflate" cele de pe spate). <_< Iar diferentele mari de diametru (punte fata vs punte spate) nu sunt agreate de ABS, DSC etc.
Iar masinile neingrijite ma duc cu gandul la faptul ca proprietarii pun si ei niste cauciucuri acolo, "sa fie", nu ii intereseaza dimensiunile sau habar nu au ce reprezinta.
Proprietarul e samsar, are 18 masini de vanzare si da, e albastru la voce. La banii astia nu ma asteptam sa fie altfel.
Eeee ce naiba sa verific f bine la o masina de 2k euro.
Daca :
e tabla dreapta pe ea
interiorul cu exceptia volanului arata de la decent in sus
daca motorul nu tremura
daca porneste bine
daca nu are socuti in cutie
daca franeaza fara sa faca balans mare
daca merge drept pe strada
daca functioneaza scaunele , ACul si in general butoanele din interior
daca nu trancane la gropi ca o masina total neingrijita
deja isi merita banii zic eu
Cu foaia de plata a taxei si originalitatea ei am o problema, n-am mai cumparat masini de cand a aparut taxa ..zdii si deci nu stiu cum sa verific daca e originala foaia aia, unde as putea sa o verific ?
La politie banuiesc ?
Masina e din Timisoara, eu din Bucuresti, nu stiu pe nimeni din Timisoara.
Daca decid sa ma duc sa o iau, greu ma mai sucesc, doar daca masina e cazan cand merg cu ea.
Nu ma deranjeaza faza cu anvelopele, iau masina pt motor + cutie + sasiu + tabla + interior.
Anvelope, planetare, bucsi, eventuala segmentare samd consider ca vor intra in acei 3000 euro care sunt alocati pt aducerea la zi dpdv mecanic.
Edited by Cumnatu
Gresesc ?
Si la revanzare mai iei ceva pe ea? Sau intrebarea e daca vei mai putea s-o vinzi vreodata.
Eu m-as baga la un E91, mai pui un pic peste suma de 6000 si iei una mult mai noua, gen 2006,2007 incolo.
Euro 4 din 2006-2008 e 6000 euro inmatricularea pe langa 7-8000 masina sa aiba ceva optiuni
Euro 5 e ok inmatricularea dar e 12-13000 minim masina.
Cele de mai sus sunt la 325, la 330 deja e nasol rau.
Nu stiu daca o sa o mai vand.
Are, dupa standardele mele ( nu asta nominal, ci ea ca si model ) tot ce ii trebuie.
Plus ca si la E91 ca la orice alt SH, trebuie sa ai pregatiti 2-3000 euro de bagat in ea, doar e SH.
Si ajung la cu totul alte sume.
Una peste alta, ori ca e deja inmatriculata si costa 12000 euro ori ca nu e si costa in germania 6-7000 si mai dai 5-6000 pe inmatriculare ajungi la 13000 euro asta FARA sa fi bagat 1 leu in ea ( distributie, uleiuri plus reparatii cele urgente )
N-am banii astia, in nici un caz gramada, plus ca .. e nu stiu ce la E46 care imi place imens de mult, estetic vorbind.
Multumesc frumos pentru orice parere si sfat !
Edited by Cumnatu
@Cumnatu avand in vedere ca masina este tocmai la Timisioara, mai bine vorbesti cu un coleg de pe forum sa se duca sa o vada, iar daca totul este ok, te duci personal sa o vezi sa nu.
http://www.bmwclub.ro/forums/topic/144001-verificarivizionari-auto-in-diferite-zone-ale-tarii-de-catre-colegii-de-forum-la-cererea-celorlalti/page__p__2103514__fromsearch__1#entry2103514
Cumnate, nu stiu ce vezi la masina aia, in afara de motor nu are nimic care sa te atraga.
Dar pana la urma la 2000E nu gaseti cine stie ce, sfatul meu ar fi sa plusezi pana la 3-4k, sigur gasesti un 330xi ok.
Crede-ma ca am studiat, cand pui X la tractiune mai pui lejer 2-3000 fata de cea mai ieftina masina cu aceleasi dotari si aceleasi motorizari.
In .ro nu exista nici un 325-330XI sub 6k, iar in .DE incep de la 3k si tinand cont si de inmatriculare samd, iese practic la 5k ca sa o ai dupa care bagi sa o repari.
Sunt zeci si sute de 2.0 diesel, nu vreau asa ceva, nu m-ar satisface si deci n-ar avea sens sa cumpar si sa investesc 6-7k euro intr-o masina care nu imi " vorbeste "
Azi sunt prea obosit sa iau vreo decizie, mai gandim 1-2 zile
Edited by Cumnatu
Cumnatule, gandeste-te ca masina aia peste cativa ani nu o sa valoreze mai nimic, indiferent de cate investitii faci tu. Cei care cauta motoare pe benzina 3.0 au bani si se prea se mai uita la E46. In prezent cei care mai cauta un E46 au in general au un buget mic sub 4000euro si majoritatea se orienteaza strict catre 2.0d cam 99% sau benzina 1.8i.
Ca o fi xdrive nu prea mai conteaza la revanzare daca e 3.0 benzina. In fine , tu ai chiar asa mare nevoie de xdrive? Stai in zona de munte spre exemplu?
Stau in Bucuresti si singura experienta cu tractiune spate a fost cu C200 Mercedes cu care am ramas suspendat. In acelasi loc nu am reusit sa raman suspendat in fix aceleasi conditii cu cel putin alte 5 masini tractiune fata ( inclusiv un amarat de Cielo ). Este posibil sa fiu eu prea prost pt RWD, este real posibil.
Nu e discutabil, in cel mai rau caz tractiune fata o sa fie urmatoarea masina, daca nu, 4x4 , nu trebuie sa fie f bun 4x4, doar sa nu fie doar RWD.
Sunt constient ca valoare de revanzare nu prea exista, deloc, nici la un diesel nu o sa mai fie valoare de revanzare peste 5 ani cand masina va avea 20 ani, sa fim seriosi.
Parerea mea e ca cei care se duc cu bani putini catre 2.0d sau 1.8i gresesc flagrant, primii pt ca acel motor la 250-350k km reali o sa le manance multicei bani ca sa fie in mintile lui, cei din urma pt ca mie personal sub 180 cai nu imi spun nimic motoarele, dar nimic. Asa sunt o galagie de masini in 3-4k f bine intretinute dar cu motoare care n-au absolut nimic spectaculos in ele. La dracu, cu 7-8k se gasesc masini aproape noi.
Nu am nevoie sa ajung din punctul A in punctul B, pot sa iau metroul, taxiul, trenul, autocarul. Am nevoie sa conduc cu placere si sub 180-200 cai nu simt mare placere.
N-am de gand sa ma bag la un consum mare si la intretinere scumpa ( pana o aduc la zi dpdv tehnic si optic ) la o masina si sa o dau rpd, nu vreau sa o mai dau deloc, parerea mea este ca 330xi are un singur minus, ca nu are o turbina sau un compresor, poate...cine stie, in timp. Altfel, masina are tot ce imi trebuie.
AAAA, ca exista acum proiectare pe ecran, nightvision, auto parking si alte balarii, sa fim sinceri, n-o sa dam niciodata banii pe asa ceva, eu unul nu.
Prefer peste 5-10 ani daca imi permit sa iau un GTR din 2011 decat un S-klasse din 2022 ( presupunand ca as avea acei bani la mom ala ) sau poate o Tesla .. aberam deja
Edited by Cumnatu
  • Like 3
  • Downvote 2
Daca ai ramas suspendat n-ai ramas din cauza tractiunii spate, ci datorita garzii mici la sol. Sub Cielo bagi linistit un om, pe cand sub C-classe bagi o palma.
Dar nah, pt Bucuresti este obligatoriu 4x4, cel putin!
Edited by LYM
N-am ramas suspendat in Bucuresti ci la munte pe piatra pisata sau cum ii spune, piatra d-aia cat pumnul , drum uscat, fara apa sau zapada.
Oricum nu vreau sa merg cu morcovul in fund iarna, indiferent de cauciucuri.
Haideti sa stabilim un lucru : ca e RWD sau 4WD , peste 5-6 ani oricum un 325 sua un 330 din 2001 nu mai are absolut nici o valoare.
La vremea aia o sa coste 4-5k euro un e90.
Deci despre valoarea ei de revanzare e clar, nu exista indiferent de motirizare sau de ce roti trag/imping.
Vad multi dintre voi care gandesc analitic despre investitia in sine si recuperarea ei. Apreciez asta.
Doar ca eu NU sunt asa, nu imi luam motor de 3.5L care sa consume... cat vrea el ... acum niste ani, mai era si americana deci valoare de revanzare aproape 0. Am dat 11k pe ea am vandut-o cu 1.5k si mergea ca in ziua achizitiei doar ca .. au centralizat astia datele si ar fi trebuit sa platesc numai impozit cam 60 mil /an
Daca peste X ani ( indiferent cat e X ) imi permit si imi place alta masina, pe asta o bag la un pret corect la vanzare sau o dezmembrez.
Daca nu, o tin si sper sa imi fie drag de ea, pana la urma lumea mai conduce si masini de 30 ani cu placere, corect ?
Iar o masina care sa aiba optiunile unui E46 full pt mine e de ajuns. ( nu vb despre masina din link ci in general de E46full )
Am detinut in proprietate 6 masini, am codus cam 30 de la 2k euro pana la 120k euro. Nici una din cele achizitionate nu a fost luata cu capul, doar cu inima. Si nu regret o secunda. Sunt prea patimas de fel sa ma multumesc cu ce e randamental corect. Imi trebuie feeling.
Sa nu poluam topicul despre analiza unei masini de 2k euro cu RWD vs 4WD sau despre cat de prost sofer sunt eu ( zisa mai in gluma mai in serios de LYM ).
Concluzie, sunt constient ca NICI o masina din 2001 nu are valoare de revanzare in 2023. E clar pt toata lumea cred, corect ?
Si totusi, de ce sa nu am in 2040 singurul E46 330xi functional ca si masina istorica , zic ?
N-am toti boii acasa, stiu :p
  • Like 4
Jur ca nu pricep ce naiba tot insistati cu valori de revanzare si cu RWD/AWD. Acum asteptam sa apara si cineva sa ii spuna sa-si ia 2.0 D ca ii consuma mai putin. Pe bune ??? Oricum deja replica clasica a fost : mai pui si ceva si iti iei modelu' nou.
4x4, penalizeaza mult la acceleratie.
Am mers cu un 330xi si nu mi s-a parut nimic spectaculos.
Macar incearca-le pe amandoua si ne spui dupa care iti place mai mult.
Edited by r0n1n
