Cum aflu consumul la relati din meniul secret E39
jhonnell
Buna , am citit pe un topic unde lumea posta consumul la relatiu la diferite motoare , eu am un E39 motor M52 , 2.8iA din 96 si as vrea din curiozitate sa aflu si eu consumul la relantiu din meniul secret . Cine poate sa ma ajute cu un sfat raman recunoscator !!!!! :twoup: si alte trucuri daca exista in acel meniu secret ! multumesc mult.
The Check Control in the instrument cluster of the E38 BMW 5/7series hides some secrets. Here is the procedure how to unveil them and how to unlock the system to get access to all tests:
• Turn ignition to pos. II
• Push right button in the instrument cluster and keep it pushed. You will first see "Check Control OK", some seconds later you will see "Test Nr.01"
• Push the left button on the instrument cluster to see the car's identification number. Add the 5 digits together and write down that number, you will need it for unlocking all the functions. Example: DG23278 will lead to 2+3+2+7+8 = 22
• Push the right button until you see "Test Nr.19"
• Push left button until you see the number that is equal to the one you calculated above
• Push right button again
Now you will have unrestricted access to Test No.3-21. If you made an error in the procedure mentioned above, Test No.3-21 will only display Lock:ON
Most of the tests are self-explanatory, and here is a first listing (as far as I can recall):
1. Display Car's identification number, HW/SW version, date of construction
2. A very beautiful instrument test
2. Current consumption (liters/100 km)
3. Current consumption (liters/hour)
4. Average consumption (liters/100 km)
5.Current range
6. N/A
7. Average fuel in tank (liters)
8. Current Speed (kph)
9. System voltage at Term. "R" (Battery Voltage)
10.Country/Language (UK, Spa, Ger, Jap, etc.)
11. Units am/pm
12. Average Speed
13. ETA
14. Date of Software Mask
15. Production Diagnosis
16. ""
17. Display Vehicle Specific Data
18. Alarm Changeover (cont. vs. intermittent OBC chime)
19. Lock/Unlock
20. Correction factor for fuel consumption (nicht ändern!)
21. Reset all defect codes
1. several numbers and data
2. [Dispay Test]
3. VBR: x,x (liters/hr)
4. RW-VBR: x,x (liters/100 km)
5. RW: x (km)
6. N/A 7. TMTL: x,x (liters)
8. V: x (kph)
9. UB: xx,xx (V)
10. LAND: 2=USA, 3=I, 4=E, 5=J, 6=F, 7=CDN, 8=AUS/GOLF, 0=D, 1=GB
11. EINHEIT 1: B3, B4, B5, B6, B7, B8, B9, BA, BB, BC, BD, BE, BF, B0, B1
EINHEIT 2: [similar to above, I didn't want to mess with it]
12. VANK: xx,x (kph)
13. ANK:xx:xx
14. ROM:
15. DIAG: 01 01 000 E3
16. PORT: 01 101010000, 02 101010000, 03...etc
17. PROM: 00 12, 01 37, 02 18, 03 E6, 04 02, 05 B3, 06 FF, 07 7E
18. HORN: DTON or [DTON flashing]
19. LOCK: ON
20. KVBR: 1000
21. RESET?
