ajutor 330xD citirea km reali?
christian22
sal rog pe cineva sa ma ajute dar as dori cineva care a facut asa ceva saucare stie sigur cum se face///
probmema mea eu vreau sa citesc km reali in bord la un bmw e46 330XD mai am un bmw un e36 318is si fac asa tin apasat butonul de resetare a kilometrajului recent (scurt) si invart cheia in contact pana la prima pozitie incepe sa imi arate 6 segvente prima din cate am inteles e cea cu kilometri reali celelalte 5 ce urmeaza nu stiu ce inseamna dupa care se aprinde bordul se duc toate acele cadranelor la maxim iar apoi se stinge ;;;;;;;;;;;ideea e ca daca fac acelasi lucru la e46 330xd nu face la fel CUM TREBUIE SA FAC,,,????PT E 46????
AM FACUT SI DIN DATELE OBTINUTE PE LANGA NISTE MESAJE CARE PRECTIC NU SUNT NISTE DATE AM DAT PESTE ASTA O SA PUN O POZA ...PROBLEMA E CA ATUNCI CAND AM REPETAT OPERATIUNEA NU AM MAI DAT PESTE NR ASTA ASA CA SUNT UN PIC IN CEATA va multumesc
Am gasit, sper sa te ajute:
Instructions to access the hidden OBC functions:
1. Hold Trip Reset while turning ignition key to on position
2. OBC should show "Test"
3. Use Trip Reset to select function 19.0 that unlocks all the features
3. Wait for display to show "Off"
4. Depress Trip Reset for 1/4 second and release it
5. With no delay press Trip Reset several times to select one of the following function s
BMW E46 On-Board Computer (OBC) Hidden Codes
nr example description
1 Car Engine and cluster data
1.0 46nnn Chassis nr/VIN serial number (last 5 digits)
1.1 4nnn K-number
1.2 690236 Cluster Part #
1.3 045210 Coding (04)/diagnosis (52)/bus index (10)
1.4 1200 Week (12)/year of manufacture (2000)
1.5 09_160 Hardware (09) and software # (16.0) of cluster
1.6 Not used
1.7 04__44 CAN-version (04) KI-revision index (44)
2 (test) Cluster System Test - Activates the gauge drivers,
indicators and LEDs to confirm function
3 SI Data
3.0 1098 Used fuel in liters since last SI (Service Inspection)
3.1 0231 Periodic inspection days; elapsed days (since last SI)
4 Momentary Consumption
4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km
4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour
5 Distance Gone Consumption
5.0 082 Average mileage; 082=8.2 liters/100km
5.1 0536 Calc. km to refuel (momentary distance to go)
6 Fuel Level sensor inputs in liters
6.0 109330+ Fuel level averaged; Left half sensor input=10.9 liters; Right sensor input=33.0 liters
6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9 liters
6.2 0442+ Indicated value (44.2) and tank phase
7 Temperature and Speed
7.0 021+ Coolant/Engine temperature (2.1C)
7.1 130 Ambient/Outside temperature - chg met 5 pts. 125/130/135
7.2 + Engine speed / Current RPMs 1/min
7.3 + Vehicle speed / Current Speed in km/hour
8 Input value in HEX form
8.0 1d0+ System voltage ADC-Value Hex code
8.1 26C33C+ ADC Values HG left/HG right
8.2 0000 ADC Value brake degradation sensor (000=o.k.)
8.3 18C ADC Value outside temperature
9 Battery
9.0 140 Battery Voltage - 140 = UB 14.0v
9.1 242013+?
9.2 074_78+?
9.3 0011+?
10 Not used
11 Not used
12 Not used
13 GonG Gong Test
14 Not used
15 Status cluster I/O-ports (bit codes) 0=low; 1=high
1st-belt contact, seat belt fastened=0; 2) ignition lock contact, key inserted=0; 3) door contact, door open=0; 4) clock button pressed=0; 5) SI reset=0, for reset=0; 6) EGS transmission failure=0
Status Digital Outputs (bits) 0=inactive, 1=active
1) Gong output; 2) Brake warning lamp; 3) Low fuel warning lamp; 4) EGA lamp; 5) seat belt lamp; 6) manipulation dot
16 Not used
17 Not used
18 Not used
19 Lock Status; unlocks functions in range 3-18
19.0 L-On/L-Off Unlock: press button when "L-Off"
20 Not used
21 Software Reset; reset OBC settings
00 End of test
Am iesit acum sa verific pe masina daca acel k-number (pozitia 1.1.) e numarul de km...nu are insa nici o legatura, sunt 4 cifre care nu stiu ce reprezinta.
Referitor la afisajul tau pe pozitia 1.2 cu 690xxx, daca te incanta cu ceva cluster part #-ul meu este cu 691xxx. :twoup:
1.1 4nnn K-number
1.6 Not used
3 SI Data
9 Battery
9.1 242013+?
9.2 074_78+?
9.3 0011+?
10 Not used
11 Not used
12 Not used
13 GonG Gong Test
14 Not used
16 Not used
17 Not used
18 Not used
20 Not used
00 End of test
merci dar nu imi apar atatea informatii si oricum nu sunt atat de bun sa le interpretez nici engleza nu stiu asa de bine le-am gasit si eu pe astea in topicul cu mici secrete pt e 46 ;;merci oricum mai astept oricum indicatii
in meniul ascuns OBC, eu nu stiu sa arate KM.... mai ales REALI, de ce ar arata in bord una si in meniu alta???
cu INPA poti vedea orele de functionare si printr-un calcul poti afla KM reali cu aproximatie...
nu stiu de ce dar pe unele(la 320 diesel am observat) nu am gasit optiunea in tester de citire a orelor... in schimb la 316i meu, la 323i al lui rgl, am gasit
Edited by Rhaziel
ok uitati - va un pic pe link-ul asta e vb de un e 36 care are 220 si ceva de mii de km in bord si cand ii face ceck ul la pozitia 1 ii apare 300 si ceva de mii de km ;;;din cate am inteles eu aia ar fi km reali ai masinii ce se vede in bord ar fi dati inapoi ;;;;memoria din ceck nu s-ar putea sterge
eu vb ce aud nu sunt sigur pe ce spun daca gresesc corectati-ma dar si explicati-mi ce inseamna
