BMW Navigation DVD Road Map Europe BUSINESS 2011
  Quote
- size, 3 DVDs Single Layer
DVD1, Western Europe
COVERAGE: Andorra, Belgium, France, Gibraltar, Great Britain, Ireland, Luxemburg, Monaco, Netherlands, Portugal (incl. Madeira), Spain (incl. Canary Isles)
DVD2, Middle Europe / Central Europe
COVERAGE: Austria, Belgium, Croatia, Czech Republik, Denmark, Germany, Italy, Liechtenstein, Luxemburg, Netherlands, San Marino, Switzerland, Slovenia, Vatican City, MRE
DVD3, Eastern Europe
COVERAGE: Bulgaria, Belarus, Croatia, Estonia, Finland, Greece, Hungary, Norway, Poland, Romania, Russia, Sweden, Slovakia
Cate un DVD pentru fiecare regiune.
  RoberTINO said:
Dar ca si vizualizare stie cineva cum vede Business hartile? Pe net am vazut doua variante:
1. http://data.motor-talk.de/data/galleries/638653/5089654/navi-business-30523.jpg
2. http://www.bmw-satnav.co.uk/images/catalog/navi_business-1.jpg
De precizat ca eu acum, fara harta de Romania, imi apare o sageata ca in prima poza, insa am gasit ceva caere spune de un update, insa nu stiu daca este valabil si la mine. (FOR I-DRIVE SYSTEMS WHERE THE DVD goes INTO THE DASHBOARD IF YOUR MAP DISPLAY HAS A TURN BY TURN ICON DISPLAY business system. Software should be 2005 or above on this system or you may require a upgrade by bmw.)
  aeerdna said:
Si dupa ce se da jos, se dezarhiveaza ISO-ul presupun... apoi cum il ard pe DVD ? exista o metoda sau un program anume ? Merge si cu Nero ? Tot vad SL asta... ce e SL ? :twoup:
- Ultra ISO - http://download.kappa.ro/action__file/id__5299.
- SL - Single Layer (un model de DVD sau dvd-urile normale). Exista si DL (dual layer).
Prima varianta. (cea de sus)
  alexandru_83 said:
A probat cineva varianta professional?
Am probat o eu.. Dvd-urile 1 si 2 merg perfect, dar dvd-ul 3 unde este si Romania face figuri. Dupa 5 min se reseteaza navigatia si se blocheaza muzica si tot. Am incercat 5 tipuri de dvd-uri si le am scris cu toate programele posibile si face la fel. Si mai stiu 3 baieti care au patit la fel.( cred ca nu este buna imaginea care circula pe internet)
  alexandru_83 said:
Am probat eu DVD-ul 3 in seara asta.Merge fara probleme :twoup:
Poti sa dai niste detalii te rog?
Cate DVD-uri sunt pana la urma? 3?
Harta prin romania cum e? Apar mai multe decat resedintele de judet?
Ce tip DVD ai scris? Cu ce? Nero e ok? Presupun ca da...
Merita update-ul facut? Ma camderanjeaza sa am 3DVD-uri in loc de unul. Mai ok era DL...
sunt 3 dvd-uri , estul, centrul si vestul europei.
harta nu stiu cum e pe acesta, eu am MK4 HIGH 2011 si merge brici.
pt al meu am folosit VERBATIME +R DL,
asta e sub 4.7 giga deci poti folosi Verbatime normal.
Foloseste IMGBURN, viteza cat mai mica. Asta am folosit eu si a mers perfect.
nush cu update-ul, ai 3 dvd-uri care oricum nu le folosesti i acelasi timp.
dvd-ul 3 este pentru romania, nu cred k e asa greu sa le schimbi cand pleci la drum in centrul sau estul europei.
bafta
bogdan
bafta
bogdan
Ce-mi plac raspunsurile astea gen nu e greu sa schimbi... :twoup:
Pai cand era DL, era doar cu cativa mega mai mult decat un DVD SL. Acum nu cred ca au dublat informatia astfel incat sa se ajunga de la un DVD SL cum e 2010 la 3 DVD-uri. Este simplu stupid... Dar daca merita, o sa trec pe DVD-uri... Asta e..
Deci? Pt cei cu professional 2011... Merita update-ul? Se castiga ceva sau e doar 2010 reluata ?
iti plac nu-ti plac asta e solutia oferita de mine... nu-i problema mea daca esti confortabil cu ea sau nu.
nu cred k s-a dublat informatia.
spre exemplu DVD-ul 3 are 2Gb si putin, aici e problema doar de timp pana vor fi puse pe un DL.
ti-am zis pt MK4 HIGH este un singur dvd 7Gb,DL.
spor
Edited by riper85
Nu am iesit in afara Bucurestiului,deci nu stiu daca are sau nu ceva in plus :)
L-am scris pe un DVD TDK cu ImgBurn...
Bafta!
  Bala said:
  riper85 said:
spor
Merci, si tie !!!
P.S. Stiu ca nu e greu sa fac un download si apoi sa scriu cateva DVD-uri insa nu am gram de timp liber si nu vreau sa ma apuc de treburi care nu au niciun rezultat...
Poti linistit sa le inscrii, eu folosesc dvdul cu Romania si merge fara nicio problema (E60 2004, nav prof). Harta e mai detaliata fata de cea de anul trecut, merita updateul.
