Cum afli daca functioneaza webasto si ce rol are?
leonardo9999
din manualul utilizatorului de exemplu:
If your car has an auxiliary fuel-burning
heater, it is also equipped with inde-
pendent ventilation control. Cars are
also supplied with independent ventila-
tion control only.
Both systems are operated via the
Multi-Information Display (MID) (see
page 88) or the on-board computer.
There is a separate Owner's Handbook
for the on-board computer.
Two different switch-on times can be
preselected, so that you can be sure
that the car's interior is warm when it is
next entered. Snow and ice are also
easier to remove from the windows.
The auxiliary heater runs for 30 minutes.
It can also be switched on and off
directly. Since its current consumption
is high, it should not be run twice in
succession unless there has in the
meantime been an opportunity to
recharge the car's battery by driving the
car.
The auxiliary fuel-burning heater can be
operated at outside temperatures
below 16 6 if the switch-on time is
preselected, or switched on directly at
any outside temperature. This only
applies when the car is driven,
however, until the engine has reached
its regular operating temperature.
The heated air is directed automatically
to the windscreen, side windows and
footwell; maximum heating output is
always used.
In ignition key position 1 you can adjust
the interior temperature, air supply and
air distribution.
The auxiliary heater continues to run for
a short period after it has been
switched off (indicator light out).
Even during the warm season of
the year the auxiliary heater
should be switched on directly about
once a month, then switched off again
after about 5 minutes.<
Do not operate the auxiliary heater
in confined spaces (closed
rooms). Always switch off the auxiliary
heater before refuelling the car.<
are rol in a incalzi mai repede interiorul masinii la temperaturi scazute.
