pot amesteca 2 tipuri de ulei castrol magnatec diesel 10w/40 daca unul are specificatia B3si altul B4?
georgian
ce inseamna b3 sau b4 mai exact? tipul de ulei e acelasi castrol magnatec diesel 10w/40 doar ca pe unul scrie b4 si pe unul b3....va multumesc anticipat
Este clasificare ACEA (Europeean Automobile Manufacturers' Association)
ACEA B3, B4 - High performance diesel passenger car, 4WD and light commercial vehicles; surpasses B2, B1, B5 (engine performance)
Edited by DanS
si are ceva daca le amestec?
complectezi sau faci un schimb "mixt" ?
cati litri are baia ?
cati litri ai din fiecare ?
completez 500ml cu b3 o sa ma uit maine pe bidon...dar dupa cate stiu eu au aceleasi specificatii..i-am bagat 4 litri cu filtru schimbat...pe joja pare a fi la jumatate aproape nivelul...dupa 2 zile de stat pe loc...si vreau sa mai completez putin
no pb. proceed.
no pb. proceed.
multumesc pt raspunsuri! salutare!
The full ACEA specs are:
* A1 Fuel Economy Petrol
* A2 Standard performance level
* A3 High performance and / or extended drain
* A5 Fuel economy petrol with extended drain capability
* B1 Fuel Economy diesel
* B2 Standard performance level (now obsolete)
* B3 High performance and / or extended drain
* B4 For direct injection passenger car diesel engines
* B5 Fuel economy diesel with extended drain capability
Teoretic nu e bine sa amesteci uleiuri, practic nu are nimic.
Edited by cristimm
