problema pornire
salutare!
aseara am fost cu masina la spalatorie,din aia automata fara perii,iar cand am iesit de acolo masina a mai mers 100 m...dupa care s-a aprins becul de la baterie si s-a oprit direct din mers; de atunci nu mai porneste deloc,dar motorul invarte...
unde naiba ar fi putut intra apa si ce mi-a ars?? k asta e cauza sigur,nimic altceva...
va multumesc anticipat pentru opinii!
DME-ul,zic eu.
injainte sa se opreasaca mergea neregulat motorul?
masina e dupa 06/1994?
On E36 BMWs manufactured prior to July of 1994, there is a design problem with the car that has caused a lot of problems with the main DME computer. The water relief channels of the car are not beefy enough to withstand a significant influx of water onto the car, or the windshield. While perfectly adequate for anything that nature may throw at the car, the channels are woefully inadequate for a car wash.
daca vrei tot articolul,citeste aici http://www.pelicanparts.com/bmw/techarticl...-DME-Repair.htm
DME-ul,zic eu.
nu,a mers normal intotdeauna....inclusiv cei 100m de la iesire...
iar masina este 04/1994..
