Obc
Vadim
pin1: violet/green/yellow, alarm system = MERGE MONTAT LA ALARMA PE CARE O AM ACUM ?? SI DACA DA CE FACE?
pin10: black/green, starter
pin6: + from fuse F17
pin9: + from fuse F20 (red/yellow)
pin8: + from fuse F1
pin22: grey/red, light switch
pin25: yellow/red, turn signal switch
pin3: white/yellow, diagnostics
pin16: white/violet, diagnostics
pin14: white/grey, instrument cluster
pin7: black/white, instrument cluster
pin4: ground
pin5: blue/red/yellow, temp sensor
pin20: black/red/yellow, pre-ventilation = ASTA E WEBASTO
pin21: black/white, pre-ventilation = IDEM 20
pin23: violet/white/yellow, alarm system = IDEM 1
pin17: red/grey/yellow, alarm system = IDEM 1
pin26: black/red/yellow, fuel tank level sensor
pin12: brown/violet, fuel tank level sensor
pin11: white/black, DME
pin24: black/violet, DME
pin19: white/red, chimes
pin18: white/blue, chimes
pin15: white/brown, radio = MERGE MONTAT LA RADIOUL PE CARE IL AM ACUM SI DACA DA CE FACE ?
pin2: blue/brown/yellow, radio = IDEM 15
