BMW Service Set 2010 - 4 DVDuri
XiE
Set of 4 discs:
ETK - SPARE PARTS CATALOGUE,
TIS - REPAIR MANUALS,
KSD - SERVICE INFORMATION
WDS - WIRING DIAGRAMS
BMW ETK LATEST 2010 VERSION + 2010 PRICES
Description of the catalogue
Original Spare Parts Catalog BMW ETK contains the information on spare parts and accessories of cars and motorcycles for all regions, since 1932 (cars) and since 1948 (motorcycles).
THIS DVD REALLY IS THE VERY LATEST, BEST AND MOST COMPREHENSIVE PARTS & PRICES REFERENCE TOOL YOU CAN GET FOR THE BMW, MINI RANGE, BMW MOTORCYCLES AND VINTAGE MODELS. THIS NEW VERSION OF THE ETK ALSO INCLUDES THE NEW 1- SERIES, 3-SERIES E-90, E-91 & E-92, E93, X1, X3, X5, X6 and MINI R53, R55, R56, R57 MODELS!
IT IS INCREDIBLY EASY TO USE PROVIDING A FULLY COMPREHENSIVE PARTS SEARCH BY SIMPLY SELECTING THE MODEL FROM THE GRAPHICAL FRONT MENU, OR MANUALLY ENTER THE VIN NUMBER AND THE ETK SYSTEM FINDS THE CORRECT MODEL AND YEAR FOR YOU.
FIND THE CORRECT PARTS NEEDED BEFORE YOU BUY IN ERROR - AND WITH THE BUILT IN 2009 PRICE LIST YOU ALSO MAKE SURE YOU ARE PAYING THE RIGHT PRICES FOR YOUR PARTS OR THAT YOU ARE QUOTING YOUR CUSTOMERS THE RIGHT PRICES WHEN PREPARING ESTIMATES FOR WORK.
ALSO INCLUDED ON THIS ETK IS THE ENTIRE RANGE OF BMW ACCESSORIES AND SPECIAL TOOLS - THIS TRULY IS THE COMPLETE BMW PARTS REFERENCE PACKAGE!
Models Covered
BMW CARS
1 SERIES - E81, E87, E87 LCI, E82, E88
3 SERIES - E36, E46, E90, E90 LCI, E91,E91 LCI, E92, E93
5 SERIES - E34, E39, E60, E60 LCI, E61, E61 LCI, F07 GT
6 SERIES - E63, E63 LCI, E64, E64 LCI
7 SERIES - E32, E38, E65, E66, F01, F02
8 SERIES - E31
X1 SERIES - E84
X3 SERIES - E83, E83 LCI)
X5 SERIES - E53, E70
X6 SERIES - E71
Z3 SERIES - E36
Z4 SERIES – E85, E86, E89
MINI
R50, R52, R53, R55, R56, R57(ONE, COOPER, COOPER S, COOPER D, ONE 1.4I AND CLUBMAN)
AND VINTAGE BMW MODELS!
BMW MOTORCYCLES:
R models K2x
K models K4x
F models K7x
S-Modelle
F models
G models
R models 4V
R models 2V
K models 4-cyl. 4V
K models 4-cyl. 2V
K models 3-cyl.
C1, C1 200
Special engines (A10B08 87-97, A61, A67)
1-CYL (R24, 225, R26, R27)
BOXER (R50, R51, R60, R67, R68, R69 1969-1976)
R-BOXER (R50/5-R90S, R45-R65LS 1978-1985)
BMW TIS
THE TIS SOFTWARE PROVIDES FULL AND COMPREHENSIVE SERVICE, TROUBLESHOOTING AND REPAIR PROCEDURES THAT ARE EASILY SELECTED AND CAN BE PRINTED OFF FOR USE AS REQUIRED - NO DIRTY WORKSHOP MANUALS EVER AGAIN!
FULL WORKSHEETS WITH 1000’S OF DETAILED TECHNICAL DIAGRAMS AND PHOTOGRAPHS COVERING EACH VEHICLE TO GIVE YOU THE BEST REFERENCE TOOL FOR THE BMW & MINI RANGE YOU CAN BUY.
YOU SIMPLY ENTER THE VIN (VEHICLE IDENTIFICATION NUMBER) AND THE TIS DVD FINDS THE CORRECT MODEL FOR YOU, OR IF YOU PREFER YOU CAN SELECT THE MODEL YOURSELF MANUALLY FROM A SIMPLE MENU.
THE TIS DVD COVERS SECTIONS ON:
TROUBLESHOOTING BY SYMPTOM (very powerful fault search system)
GRAPHICAL REPAIR SEARCH (very useful if you don't know the part name)
SERVICE REPAIRS (step by step service procedures)
REPAIR INSTRUCTIONS (repair to a professional standard!)
TECHNICAL DATA
TIGHTENING TORQUES
FILLING CAPACITIES
INSPECTION SHEETS
COMPUTER DIAGNOSTIC CODES
ENGINE PERFORMANCE
TRANSMISSION REMOVAL & INSTALLATION
SUSPENSION
AIR CONDITIONING
ENGINE OVERHAULS
WHEEL & DRIVETRAIN SPECS
BRAKE SERVICING PROCEDURES
FACTORY MAINTENANCE SCHEDULES
SI OPERATING FLUIDS
SPECIAL TOOLS/APPLIANCES
TECHNICAL REFERENCE BULLETINS
Models Covered
1 SERIES –E81, E82, E87, E88
3 SERIES - E30, E36, E46, E90, E91, E92, E93
5 SERIES - E34, E39, E60, E61
6 SERIES - E63, E64
8 SERIES - E31
X SERIES - E53, E70, E83
Z SERIES - E85, E86
M-SPORT VERSION - R50, R52, R53, R55, R56
INCLUDES OLDER BMW VINTAGE MODELS
BMW KSD2 2009 version
THE BMW KSD CONTAINS THE FULL CATALOGUE OF FLAT RATES, DEFECT CODES, SERVICE & REPAIR PACKAGES AND WHEEL/TYRE COMBINATIONS SINCE 1961! - ALL 114 SERIES ARE COVERED!!
The program BMW KSD works with CD, installation does not require, support many languages. The interface of the program maximum simple and convenient. There is identification by VIN.
The program BMW KSD is simply irreplaceable for car-repair centers specializing on repair of automobiles BMW, as allows making for the client complete accounting of works and their cost, on the basis of official data of the manufacturer.
Models Covered
ALL MODELS SINCE 1961
BMW WDS v12.0
THE WDS-12 IS THE MOST COMPREHENSIVE AND UP TO DATE SOURCE OF WIRING DIAGRAMS AND ELECTRICAL INFORMATION AVAILABLE FOR THE BMW RANGE
FULLY DETAILED WORKSHOP WIRING DIAGRAMS/SCHEMATICS/PIN-OUTS ARE EASILY SELECTED AND CAN BE PRINTED OFF FOR USE AS OFTEN AS REQUIRED
ALL INFORMATION IS EASILY LOCATED WITH VERY EASY TO USE CONTROLS SO YOU CAN INSTANTLY FIND WHAT YOU NEED IN THE SHORTEST POSSIBLE TIME
WDS BMW Wiring Diagram System
WDS is used to view wiring diagram information.
WDS is a browser-based application running in Internet Explorer.
WDS contains the following data:
- Wiring Diagrams
- Pin Assignments
- Component Locations
- Connector Views
- Functional Descriptions
- Measuring Devices
- Desired Values
- Help Texts
- Functional Tests
THE WDS DVD DOES NOT EVEN NEED TO BE INSTALLED AS IT SIMPLY RUNS FROM YOUR BROWSER AND QUICKLY GIVES YOU ACCESS TO CLEAR AND FULLY DETAILED TECHNICAL WIRING DIAGRAMS AND CLEAR PHOTOS WHEN YOU NEED THEM IN SECONDS!
Models Covered
BMW 7, E38 03/94-09/98
BMW 7, E38 09/98
BMW 5, E39 12/95-08/98
BMW 5, E39 ?? 08/98
BMW 3, E46
BMW 1, E81, E82, E87, E88
BMW 3, E90, E91, E92, E93
BMW 5, E60, E61
BMW 6, E63, E64
BMW 7, E65, E66, E68
BMW X3, E83
BMW X5, E53
BMW X5, E70
BMW Z4, E85, E86
BMW Z8, E52
PRETUL celor 4 DVDuri este de 150RON + Transport (curier sau posta romana)
Telefon - 0764.709.399 Alex
Se gasesc pe net gratis!@!!!!!
pune un link .o adresa
Ar fi bine ca toate programele de service sa se gaseasca asa pe oriunde...dar ce le facem la updateuri? sau la conexiunea la internet care poate ar trebui sa fie necesara?
Aceste programe nu necesita update-uri....se instaleaza cu totul noua versiune.....despre ce conexiune la internet vorbesti??? Aceste programe odata instalate lucreaza independent de net....
Era vb de nevoia la internet pentru programele free de care spune Kathalin, dar daca nu ai internet ce faci? Cumperi aceste programe (care cum ai spus tu ruleaza fara net).
O seara buna!
TIS=ul e pe torente :twoup:
Sunt toate pe torente :) eu zic ca 100 lei ar fi echitabil pt ca nu multi pot sa le gaseasca si poate unii nici n-au chef sa faca asa ceva
Programele sunt originale BMW si nu necesita activare/licentiere de catre utilizator.
din poza vad ca WDS e ver. 12, adica vechi de cativa ani buni, ce vinzi tu nu are nicio legatura cu "2010 sau originale bmw"...fara suparare dar nu e corect sa spui una si sa faci alta...stiu foarte bine cum arata discul original de etk si nu are nicio legatura cu cel din poza postata de tine
bafta la vanzare
14. Daca se ofera spre vanzare softuri de diagnoza auto sau alte softuri care nu au legatura cu auto trebuie precizat daca sunt oferite cu licenta. Toate produsele care nu au licenta si sunt de domeniu piraterie vor fi sterse automat.
se inchide
