Vand diferite piese BMW E36 E46 E21 E28 E30 (super pret)
Ce piese scriu decat atata mai am per model.
E36 am cele mai multe
toate preturile sunt negociabile lichidare garaj
cine ia mai multe reduceri mai mari
PIESE E21
Cardan ambele bucati 30 ron/buc
Cuitie viteze 4+1 80 ron
Piese motot M10 1600
bobina 60 ron
Alternator 80 ron
Electromotor 80 ron
Delcou Complet 80 ron
kit ambreaj disk+placa 80 ron
pompa apa 50 ron
pompa ulei 50 ron
senzori apa termostat 30 ron
fete usi fata spate albastre 30 ron/buc
Consola centrala 50 ron
PIESE E28[/size][/size]
Grup normal carcasa mare + planetare +suport caroserie+cardan spate 300 ron
Caseta servodirectie 100ron
pompa ambreaj 80 ron
pompa frana+tulumba 80 ron
Usi 80 ron/buc
aripi 80 ron/buc
tragar 80 ron
capota 80ron
haion 50 ron
faruri 80 ron/buc
stopuri 50 ron/buc
grile fata 50ron
bord/consola/calculaor/ceas/etc - pret negociabil
luneta incalzire 80ron
Alte piese interior...etc
Piese motor M30
alternator 100 ron
electromotor 150 ron
pompa ala + vascocuplaj 100 ron
delcou complet 100 ron
calculator m30b28 50 ron
diac 50 ron
debitmetru m30b28 80 ron
pistoane m30b28 (se pot pune pe m20b25) 150ron toate
bobina 60 ron
PIESE E30
pompa ABS 120 ron
piese motor m40b18
bobina 60 ron
fise+delcou 80 ron
alternator 100 ron
PIESE E46
Piese motor 1800 8v an 2000
Electromotor 150 ron
Alternator 150 ron
Pompa servo 150 ron
PIESE E36 coupe
Use dreapta 150 ron(fara macara)
macara drepta + motor 100 ron
macara stanga 40 ron (fara motor)
tripla M dreapta 60 ron
Pompa ABS 120 ron
calculator abs 80 ron
discuri spate plus etrieri 50ron/buc (foarte bune)
planetara staga grup deschis 60 ron
grup deschis 100 ron(carcasa are urechi rupte si fara senzor)
tot felul de butoane bord, topedou,diferite suruburi
consola crem 30 ron
mocheta crem 40 ron
pistoane+ biele 1,8is 30ron/buc
radiator ac 120 ron
compresor AC pt 6 pistoane 200 ron
elcromotor pt 6 pistoane 140A 240 ron
vascocuplaj 6 pistoane 60 ron
bara spate 80 ron (fara armatura si fara bandouri)
rulment spate 50 ron/buc
etrieri frana de mana 60 ron/buc
motor trapa electrica 100ron
trapa electrica mecanism 150 ron
admisie 1,8is normala 150 ron/buc
clapete 1,8 60 ron
plus vacumuri senzori motor 1,8is
capac culbutori 1,8is 50ron
tel:0767140877
