Vand DVD 2DIN Kenwood ddx7029 DivX Touchscreen
pret 1600lei
6.95 inch Interactive Touch Panel Control with Full Graphic User Interface
USB Interface
iPod USB Direct Connection with optional cable (KCA-iP200 or KCA-iP300V (iPod-Video))
iPod Full Control/ iPod Video/ iPod Album Art
Maximum Output Power : 50W x 4 (MOSFET Power IC)
1 RCA AV In, 1 RCA AV Out, 1 RCA Video Input for Rear View Camera
System E's+ (Built-in HPF/LPF), System Q-sp
DVD Video/-VR/±R/RW, DivX, MPEG 1/2 Video File (.mpg) & JPEG File (.jpg), AAC, WMA, MP3 playback
Bluetooth Handsfree with Optional Unit (KCA-BT100)
General Features
DIN Size 2 DIN
Detachable Faceplate No
Disabled System Indicator (DSI) Yes
Security Code Function (Factory fit) Yes
On Screen Display (OSD) Operation Yes
Smooth GUI Yes
Selectable GUI Background Wallpaper Yes
Key Illumination Blue
Installer Memory Yes
Back-up Memory Yes
Attenuator with Smooth Volume Return Yes
Touch Sensor Tone Yes
Optional IR remote controller Yes
IR Remote Control included RC-DV340
Digital Clock (24H) Yes
ISO connector Yes
Optional Bluetooth unit Yes, KCA-BT100
Optional navigation system unit Yes, KNA-G520
Made for iPod Yes
Monitor Features
In-Dash/On-Dash In-Dash
Screen Type TFT 6,95" Wide
Display Mode 4 Mode (Full/Just/Zoom/Normal)
Screen Adjustments Brigtness/Tint/Color/Contrast/Black Level
Dimmer function Manual
Visual Source Mode DVD/Video/Navigation/(TV)/USB/iPod
Touch Panel Yes
Mechanism type Auto Slide
Mechanism Angle Adjustment 6 steps
Reverse Tilt Yes
NTSC/PAL judge Auto
Multimedia GUI Features
OSDC Type Full Graphics
Colour Pallet 256
Base Colour Class 65000
Menu character font English
Menu text English, Greek, Cyrillic
Background Customize Yes
Skin Change Yes, 3 types
Tuner Features
Radio Data System Yes
Radio Text Plus Yes
Program Type Function (PTY) Yes
Enhanced Other Networks Function (EON) Yes
K3I - Clean Reception Tuner Yes
FM Reception Yes
AM (MW/LW) Reception Yes
Presets 24 Presets (18FM / 3LW / 3MW)
Station Select List
Automatic Memory Entry (AME) Yes
Up/Down Seek Tuning Yes
Tuning mode (Auto1 / Auto2 / Manual) Yes
FM Stereo / Mono Selector Yes
DVD-Features
Mechanism DVS-8500
Disc Capacity 1 Disc(s)
DVD±R/RW Compatible Yes
DVD Region Code 2
VCD Compatible Yes
CD-R/RW Compatible Yes
CD Text Yes
MP3 Yes
ID3 Tag Yes
WMA Yes
WMA Tag Yes
AAC Yes
AAC Tag Yes
Digital/Analog Converter 24 bit
Shock Proof Yes
2nd Disc Prevention Mechanism Yes
MPEG1/2 Video File (.mpg) Compatible Yes
JPEG File (.jpg) Compatible Yes
DivX (Certified) Yes
CD-DA Repeat/Scan/Random play Yes
CD-DA Disc Name Preset (10 disc's) Yes
Direct Search Yes
Time Code Display Yes
Resume Play Yes
Zoom Control (DVD/VCD) Yes
Disc Menu Direct Touch Yes
Picture Control (JPEG) Yes
USB Features
USB terminal Yes, rear side
USB Type USB1.1 / USB 2.0
MP3 playback with ID3 Tag Display Yes
WMA (Windows Media File) playback Yes
AAC (Advanced Audio Codec) playback Yes
iPod Features
iPod control by 5L bus Yes, with optional KCA-iP500
USB Video & Audio direct control (3 wire) with optional KCA-iP300V
Music playback Yes
Video playback Yes
Album art support Yes
Music library search Yes
Works with iPod Classic *
Works with iPod Video * 5th/6th generation
Works with iPod Touch * 1st/2nd Gen
Works with iPod Nano * 1st/2nd/3rd/4th Gen
Battery charge + power control Yes
* Always update to latest Apple firmware
External Media Control Features
Dual Changer Control (CH1, CH2 & AUX) Yes
CD Text Ready with Compatible KENWOOD Units Yes
Disc & Track Repeat Yes
Disc & Track Scan Yes
Disc & Track Random Play Yes
Direct Access Yes
Disc Name Preset Play (DNPS) Yes
Audio features
Max. Output Power (MOSFET Power IC) 4 x 50W
Pre-out 3RCA: Front/Rear/Subwoofer
Pre-out Output Level 2V
Auxiliary Input
Subwoofer Reference Level Adj. Yes
Dual Zone Source & Volume Control Yes
Dual Zone (FRONT / REAR Switchable) Yes
Source Tone Control & Memory Bass / Mid / Treble
Balance/Fader Control Yes
Loudness Control Yes
Att.(-20dB) with smooth Volume Return Yes
System Qsp (Preset Sound Control) Yes
System E's+ (Built-in HPF & LPF) Yes
Beep On/Off Yes
Video Features
Audio/Video Output 1 RCA
Audio/Video Input 1 RCA
Video-In for Rear-view Camera 1
Mirror-mode on Rear-view Image Yes
Detection Mode Rear View Camera Reverse sensor wire
RGB Input For Navigation System Yes
DVD Menu Direct Touch Operation Yes
MPEG Decoder Yes
TV ready Yes
TV- tuner Features
PAL System Yes
SECAM System Yes
Band TV1/TV2
Preset 12 (6ch x 2 Band)
Tuning Mode Auto1/Auto2/Manual
Auto Memory Entry Yes
Audio Type Normal
Station Name Preset Yes
Connectivity
Changer Control (5L-Bus) Yes
AUX input (5L-Bus) Yes
iPod I/F Control (5L-Bus) Yes
Bluetooth Control (5L-Bus) Yes
PS Amplifier Control System (5L-Bus) Ps Amplifiers ('02 - '06)
iPod Direct Control (2 wire) Yes
iPod Video Direct Control (3 Wire) Yes
OEM Wired Remote Control Yes
Parking sensor wire Yes
Reverse sensor wire Yes
Power Control (P.CON) wire Yes
External Amplifier Controle Wire Yes
2-way (Tel/Navi) mute wire Yes
Dimmer control wire Yes
TV Tuner Control Yes
Navigation RGB terminal Yes
Tuner Specifications
FM Frequency Range 87.5MHz ~ 108MHz
FM Frequency Step 50kHz
FM Usable Sensitivity 0.7μV/75ohm (S/N 26dB)
FM Quieting Sensitivity 1.6μV/75ohm (S/N 46dB)
FM Frequency Response 30Hz ~ 15kHz (± 3dB)
FM Selectivity(DIN) over 80dB (±400kHz)
FM Stereo Separation (1kHz) 35dB
MW Frequency Range 531kHz ~ 1611kHz
MW Frequency step 9kHz
MW Usable Sensitivity 25μV (S/N 20dB)
LW Frequency Range 153kHz ~ 281kHz
LW Usable Sensitivity 45μV (S/N 20dB)
DVD Specifications
D/A Converter 24 bit
Video decoder Linear PCM/Dolby Digital/dts/MP3/WMA/AAC
Wow & Flutter Below Measurable Limit
Freq. Resp. (96kHz Sampling) 20Hz ~ 44kHz
Freq. Resp. (88,2kHz Sampling) 20Hz ~ 40kHz
Freq. Resp. (48kHz Sampling) 20Hz ~ 22kHz
Freq. Resp. (44,1kHz Sampling) 20Hz ~ 20kHz
Total Harmonic Distortion 0.008% (1kHz)
Signal to Noise Ratio 100dB (1kHz)
Dynamic Range 100dB
Disc Format DVD-Video/Video-CD/CD-DA
FM Signal to Noise Ratio 65dB(MONO)
Sample Frequency 44.1kHz/88.2kHz/96kHz
Sample Frequency 44,1/48/88,2/96kHz
Quantifying bit number 16/20/24bit
USB Specifications
USB Version compatibility 1.1 / 2.0
File System FAT 16/32
Maximum Supply current 500mA
MP3 Decode Compliant with MPEG-1/2 Audio Layer-3
WMA Decode Compliant with Windows Media Audio
AAC Decode AAC-LC "m4a" Files
WAV Decode no
Audio Specifications
Maximum Power 50W x 4
Output Power (DIN45324,+B=14.4v) 30W x 4
Preout Level 2000mV / 10kOhm,
Preout Impedance ≤ 80Ohm
Speaker Impedance 4Ohm ~ 8Ohm
AUX Input Impedance 10kOhm
Bass Tone Control 100Hz ±10dB
Middle Tone Control 1kHz ±10dB
Treble Tone Control 10kHz ±10dB
Video Specifications
Color System of External Video Input NTSC/PAL
External Video Input Level (RCA) 1Vpp / 75Ohm
External Audio Max. Input Level (RCA) 2V / 25kOhm
Analog RGB Input 0.7Vpp / 75Ohm
Video Output Level (RCA) 1Vpp / 75Ohm
Audio Output Level (RCA) 1.2Vpp / 10kOhm
Monitor Specifications
Screen size (Diagonal) 6.95 Inches Wide
Screen Size (WxH) 156.2 x 82.4mm
Display system Transparent TN LCD Panel
Drive system TFT Active Matrix System
Number of Pixels 336960pixels (480(H) x 234(V) x RGB)
Effective pixels 99.99%
Pixel arrangement RGB Striped
Back lighting Cold Cathode Fluorescent Tube
General Specifications
Operating voltage 14.4V (11 ~ 16V Allowable)
Maximum Current Consumption 15A
Dimensions (WxHxD) 182 x 112 x 161mm
Weight 2750gr
Operation Temperature Range -10°C ~ 60°C
Storage Temperature Range -20°C ~ 85°C
Instruction Manuals ENG/FRE/GER/DUT/ITA/SPA/POR
Accessories
Remote control RC-DV340
Battery included Yes, 2 x AAA
Antenna Adapter ISO to JASO
Release keys 2 pieces
Escutcheon Yes
Installation Sleeve Yes
DC cord (Molex to ISO) 30 cm
MamĂŁĂŁĂŁ...
Are mai multe opÞiuni decât un 7ar extra/mega/full de full!
wow...pentru cateva clipe chiar am incercat sa citesc ce scrie pacolo..pune si tu mai multe poze te rog. p.s. asiguri montaj?
Nu mĂŁ bag la montaj. Nu mĂŁ pricep..
anuntul este pus de @forexmaster, care nu stiu din ce oras este. Raspunsul legat de montaj este dat de @Rares_CJ. Este vorba de acelasi user ca sunt in ceata?
Si inca o intrebare: are navigatie?
Edited by Gimi
Sunt din bucuresti. nu asigur montaj ca nu ma pricep.....
E smecher DVD-ul, am amvut vreo 4 asemanatoare pana acum, diverse marci dar acesta nu a
avut nici o problema niciodata...urmeaza sa pun si alte poze.
nu are receiverul GPS dar se poate pune extra.nu e scump
bineinteles...se cheama ''clone'' :twoup:
am un singur cont....nu cunosc acel user
7. Initiatorul topicului poate da un singur UP la 7 zile de la ultima sa postare. Nu se admit UP-uri date mai repede de 7 zile de la ultima postare sau UP-uri date de catre alta persoana decat initiatorul topicului. Exceptia UP-ul la 7 zile va fi permis doar atunci cand initiatorul doreste sa scada 10% din pret. Daca se da UP inainte de cele 7 zile topicul va fi inchis 10 zile. Sunt considerate UP-uri si actualizarile de stocuri, noi produse, sau postarea de poze in intervalul celor 7 zile. Din acest motiv, topicurile trebuie sa contina cat mai multe informatii inca de la deschiderea lor.
