Cum dau Jantele cu ET40 pe un E39?
red&bluestar
1 - E81/82/87/88 = PCD 5x120, diametru interior janta 72.5mm. ET 35-45
3 - E36 = PCD 5x120, diametru interior janta 72.5mm. ET 30-40
3 - E36 M3 = PCD 5x120, diametru interior janta 72.5mm. ET 30-40
3 - E46 = PCD 5x120, diametru interior janta 72.5mm. ET 30-45
3 - E46 M3 = PCD 5x120 diametru interior janta 72.5mm. ET 20-25
3 - E90/91/92/93 = PCD 5x120, Diametru interior janta 72.5mm. ET 30-45
3 - E90/92/93 M3 = PCD 5x120, Diametru interior janta 72.5mm. ET 34-37
5 - E34 = PCD 5x120, diametru interior janta 72.5mm. ET 13-20
5 - E34 M5 = PCD 5x120, diametru interior janta 72.5mm.
5 - E39 = PCD 5x120, diametru interior janta 74.0mm. ET 15-25
5 - E39 M5 = PCD 5x120, diametru interior janta 72.5.0mm. ET 15-25
5 - E60/61 = PCD 5x120 diametru interior janta 72.5mm. ET 15-32
5 - E60 M5 = PCD 5x120, diametru interior janta 72.5mm. ET 12-32
5 - E61 M5 = PCD 5x120, diametru interior janta 72.5mm. ET 12-32
6 - E63/64 = PCD 5x120, diametru interior janta 72.5mm. ET 14-20
6 - E63/64 M6 = PCD 5x120, diametru interior janta 72.5mm. ET 12-20
7 - E32 = PCD 5x120, diametru interior janta 72.5mm. ET 19-26
7 - E38 = PCD 5x120, diametru interior janta 72.5mm. ET 13-25
7 - E65/66/67/68 = PCD 5x120, diametru interior janta 72.5mm. ET 15-25
8 - E31 = PCD 5x120, diametru interior janta 72.5mm.
X3 E83 = PCD 5x120, diametru interior janta 72.5mm. ET 40-45
X5 E53 = PCD 5x120, diametru interior janta 72.5mm. ET 40-45
X5 E70 = PCD 5x120, diametru interior janta 74.0mm. ET 37-53
X6 E71 = PCD 5x120, diametru interior janta FATA 74.0mm, diametru interior janta SPATE 72.5mm.
Z3 E36 = PCD 5x120, diametru interior janta 72.5mm. ET 30-40
Z3 M Coupe/M Roadster = PCD 5x120, diametru interior janta 72.5mm.
Z4 E85 = PCD 5x120, diametru interior janta 72.5mm. ET 45-52
  • 8 years later...
Buna seara ! Am un BMW E60 din 2009 cu jante pe 17 ET20, tractiune spate. Mi-am achizitionat 4 jante model BMW 6790172 8Jx17EH2+IS30 (ET30).Va rog daca ma poate ajuta cineva cu un raspuns la urmatoarele intrebari! Imi trebuie distantiere si ce marime? Alte prezoane si ce marime? Va multumesc anticipat! George
