Antigel
Billy
  • Replies 408
N-am reusit sa-l golesc tot, ca n-am gasit busonul de pe blocul motor. Cel putin nu prin zona prin care era in filmuletele sau tutorialele de pe net. Mi-au intrat aproape 6 litri. A venit cu un antigel roz si ala cam diluat, ca era doar la -15. I-am pus BMW G11 albastru acum. O sa-l scot tot cand fac si schimbul de ulei la primavara, ca tot trebuie sa schimb si niste garnituri.
Foarte bine ca ai pus G11 pt ca ala e recomandat la bmw. Dar aia e,ai bagat 6 litri si ceva si daca goleai si blocul motor intrau inca un litru jumate deci 7,5-7.8 in total.
Luam la intamplare BMW 5 (E60); 525 d; kW 120
*Engine oil with filter 8,25 litres
*Engine oil viscosity BMW Longlife 04 SAE 0W-30|SAE 0W-40|SAE 5W-30|SAE 5W-40
*Engine oil specification BMW Longlife-04
*Manual gearbox oil Gearbox GS6-53DZ 1,60 litres
*Manual gearbox oil specification
-up to 2007/02, Gearbox GS6-53DZ 83 22 0 309 031 Original oil
-from 2007/03, Gearbox GS6-53DZ 83 22 7 533 818 Original oil
*Automatic gearbox oil
Gearbox GA6HP26Z, New filling 9,50 litres
*Automatic gearbox oil specification
Gearbox GA6HP26Z 83 22 0 142 516 Original oil
*Rear axle oil specification 33 11 7 695 240 Original oil
*Power steering oil 1,00 litres(4)
*Power steering oil specification
Cover marking ATF 81 22 9 400 272 Oil colour red
Cover marking CHF 83 29 0 429 576 Oil colour green
*Cooling fluid specification 83 19 2 211 191 Original anti-freeze agent
*Brake fluid when changing 1,00 litres
Brake fluid specification 83 13 0 443 026 Original brake fluid
*Air-conditioning system refrigerant
690 - 710 Gram The definitive information is given on the type designation plate in the engine space.
*Refrigerant specification R134a
*Air-conditioning system oil
170 - 190 cm³ The definitive data is given on the type designation plate of the air-conditioning compressor.
*Air-conditioning compressor oil specification 81 22 9 407 724 Original oil
Compressor oil refilling quantity when replacing the high-pressure line 35 cm³
Compressor oil refilling quantity when replacing the low-pressure line 35 cm³
Compressor oil refilling quantity when replacing the compressor 50 cm³
Compressor oil refilling quantity when replacing the condenser
Condenser with integrated dryer 55 cm³
Compressor oil refilling quantity when replacing the dryer
Compressor oil refilling quantity when replacing the evaporator 35 cm³
(4)Data are guide values! Finally check filling level on the vehicle!
Cooling fluid specification 83 19 2 211 191 este antigel albastru.
