[Vand] M43B16
Vand Motor M43B16 din 1996/01 cu 170.000 km.
Are distributie noua (lant, patine, intinzator) si pompa de apa noua (Beru cu pale de metal).
Se vinde cu evacuare completa (finala+catalizator+sonda lamba), instalatie electrica, DME, EWS si cip cheie. Nu mai are cutie, starter si alternator.
Motorul functioneaza foarte bine, nu se vinde din cauza vreunui defect.
Pret :800 RON
Se vinde in....parti!
Instalatie electrica(cutie, cabluri, mufe)-50;
Relee-30
Sensor arbore-60;
Senzor ax cu came-60;
Senzor temperatura lichid racire-20;
Senzor detonatie-50;
Furtune vacuum-20;
Lant distributie(3000km)-100;
Patine-80;
Tensionator lant(3000km!)-130;
DME-200;
EWS+cip cheie-110;
Evacuare finala-130;
Valva PCV-60;
Corp/clapeta acceleratie-20;
Ambreiaj-150;
Termostat-80;
Furtune radiator (2)-60;
Injectoare (4)-110;
Rampa injectie/reg. presiune-100;
Debitmetru-200;
Bobina inductie-40;
Fise inductie-60 toate 4
Up!
Relee-30
Sensor arbore-60;
Furtune vacuum-20;
Patine-80;
DME-200;
EWS+cip cheie-110;
Evacuare finala-110;
Valva PCV-60;
Ambreiaj-130;
Termostat-70;
Injectoare (4)-110;
Debitmetru-200;
Bobina inductie-40;
Fise inductie-50 toate 4
Bloc motor, chiulasa, pistoane etc-300 ron
Edited by Cristi B
valabil....
Instalatie electrica(cutie, cabluri, mufe)-30;
Relee-20
Sensor arbore-40;
Senzor ax cu came-40;
Senzor detonatie-20;
Furtune vacuum-20;
Patine-80;
Evacuare finala-500;
Valva PCV-20;
Ambreiaj-130;
Termostat-30;
Furtune radiator (2)-50;
Injectoare (4)-60
Rampa injectie/reg. presiune-70;
Debitmetru-110
Bobina inductie-30;
0741741186
Edited by Cristi B
Relee-30
Sensor arbore-40;
Furtune vacuum-20;
Patine-80;
Evacuare finala-70;
Valva PCV-30
Ambreiaj-90
Termostat-70;
Injectoare (4)-90;
Debitmetru-170;
Fise inductie-30 toate 4
Edited by Cristi B
Relee-30
Sensor arbore-40;
Furtune vacuum-20;
Patine-80;
Evacuare finala-70;
Ambreiaj-90
Termostat-70;
Injectoare (4)-90;
Se dau toate la 300 ron
  • 3 months later...
Sensor arbore 30
Senzor ax cu came 30
Senzor temperatura lichid racire 20
Senzor detonatie 20
Furtune vacuum - trebuie sa verific care mai sunt
Evacuare finala 60
Ambreiaj nu mai este
Termostat trebuie sa verific daca il mai am
Furtune radiator 40
Fise inductie 30
Daca vrei tot ce are pus pretul mai sus, facem 200 ron, fara termostat si fara furtunele de vacuum despre care nu stiu daca le mai am (verific diseara)
Edited by Cristi B
